928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel line clamps around barbs...how tight?
Old 02-24-2012, 12:59 AM
Dean_Fuller
Dean_Fuller's Avatar
Default Fuel line clamps around barbs...how tight?
After reading some more on the world wide internet I now fell a little uneasy.
I just replaced fuel lines on my car and my sons. After cutting the crimps off and adding real nice fuel injection clamps...I got to thinking. Just how tight should one tighten the clamps around hose over the barbs. I used a screw driver ( not a socket ) and tightened them as tight as I could without turning red. In other words I tightened till it was a lot of resistance and stopped. Now I'm thinking I may be too tight. I can visualized the barbs maybe cutting into the inside of the hose....
How tight is TOO tight....how do you know when to stop tightening.
I'm not too proud to ask when it comes to an open flame under my car....or me son's.
Old 02-24-2012, 02:13 AM
NoVector
NoVector's Avatar
On the Ultimate Garage website, they show their ABA mini clamps having a tightening torque of 1.1ft lbs or 13.3 inch lbs. Fuel clamps also have the rounded edges so they don't cut into the line. Since you just used a screwdriver and not a driver, I'm thinking you're okay. I always get them snug--and then a little bit more. And then I put a dab of paint on it... Kind of related, any other fuel lines I do, I'm going to double clamp them (Greg's idea.)
Old 02-24-2012, 09:58 AM
renaissance.man
renaissance.man's Avatar
I think you are okay. Fuel line is a reinforced hose, so it is difficult to damage it by over tightening it.
I definitely put my clamps on really tight since I have seen fuel weep out of a moderately tight clamp. In this situation, I think there is a higher chance of creating a fire.
Old 02-24-2012, 11:39 AM
FredR
FredR's Avatar
On my r/r of the fuel lines I tightened them until the clamp was more or less flush with the OD of the hose. I used two clamps at each point. That naturally spaces the clamps to some extent.
Use of a screw driver is fine- a bit of common sense on applied torque is needed. it does not need gorilla torque to work.
Fred
Old 02-24-2012, 03:18 PM
ROG100
Basic Sponsor
ROG100's Avatar
Dean,
Remember it is the barbs that do the sealing. The axial end thrust of the hose under pressure allows the barb to press into the wall of the hose and make the seal.
The clamp is an extra level of safety and two would be extra extra safe.
Roger
Old 02-24-2012, 03:22 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Dean--
If this is related to the other thread about the new-tech plastic-lined fuel hose and clamps, the Most Critical thing is to make sure that the clamp isn't deforming the hose right at the barb or bead. Maybe one hose-wall-thickness away should be fine. Then I use 14 inch/lbs as a guide number; that value came from some irrefutable Internet source that I've forgotten. Anyway, after the 14 inch/lbs, clamps can be adjusted tighter as needed to stop leaks. Call it 'empirical torque adjusting'.
Old 02-24-2012, 03:31 PM
robot808
robot808's Avatar
I tightened mine tight, but not too tight.
Old 02-24-2012, 03:48 PM
ROG100
Basic Sponsor
ROG100's Avatar
tight is good 8>)
Quick Reply: Fuel line clamps around barbs...how tight?
