928 Forum 1978-1995
Sponsored by: 928 Specialists
How to tighten this style CV boot clamp?
Old 10-05-2011, 11:05 PM
blown 87
Rest in Peace
blown 87's Avatar
Originally Posted by Randy V
I'm suprised 928 International supplies a kit with those crappy clamps.
I refuse to use anything but the ones like that, or the solid ones that have no adjustment.
Old 10-05-2011, 11:07 PM
blown 87
Rest in Peace
blown 87's Avatar
Originally Posted by ZEUS+
With cv boot clamp pliers like this. You can use diagonal cutting pliers also if your careful.
I use the same set.
I wish I had a source for the clamps in all sizes, I would use them instead of Zebra (screw type) clamps.
Old 10-05-2011, 11:08 PM
928mac
928mac's Avatar
Do you mean the side cutters Greg or the proper clamp pliers?
I have the CV boot clamp pliers but sometimes I find that the side cutters crimp it better and tighter.
Old 10-05-2011, 11:44 PM
blown 87
Rest in Peace
blown 87's Avatar
The factory type tool, never had a problem, but you have to keep everything clean at the boot to metal.
To tight is not good, seen more than a few cut the boot because they were not free of grease between the boot and the CV itself, and almost always on the big end.
Old 10-06-2011, 01:57 AM
Ad0911
Ad0911's Avatar
I used pliers that are commonly used to break off small pieces from bathroom tiles. Very cheap to come by but I happened to have one.
Old 10-06-2011, 02:43 AM
NoVector
NoVector's Avatar
Thanks everyone - I used a pair of hog-ring pliers to pinch it; seems to be good and tight now.
Originally Posted by dr bob
Gear/screw clamps are a balance problem, so the ones with the smallest out-of-balance problem get the nod.
I guess you could screw two small clamps together to counter-balance each other, but then it would be a become a PITA and they'd probably get in the way of the 6 axle bolts.
Old 10-06-2011, 08:47 AM
jeff spahn
jeff spahn's Avatar
I didn't get mine tight enough and grease flew out. Gotta re grease the inners this winter and re do the clamps. Perhaps I'll just have the local shop regrease and have them put the clamps on
Old 10-06-2011, 10:57 AM
NoVector
NoVector's Avatar
Jeff - I think that's 1/2 the battle. The other is not getting grease into the lip of the boot while trying to get it on the flange. What i learned after the first axle is: just becuase there's two tubes of grease, I didn't have to fill it to the rim before sliding the boot down. On the second axle, I used a leftover turkey injector (from my deep-frying days) filled it full of grease and then inserted it between the shaft and the boot to top it off. I'll know tomorrow if it worked I'll say it again though, what a crappy job...
Old 10-06-2011, 11:09 AM
SteveG
SteveG's Avatar
Originally Posted by Dictys
Is that the same tool used for the tensioner boot clamp?
The last factory tensioner boot clamp I rec'd was the threaded screw type.
Old 10-06-2011, 12:54 PM
Ad0911
Ad0911's Avatar
Funny, there seems to be different ways of doing the same job. As I recall the sequence I used was as follows:
1. put the new boot on the flanges and stick new seal on the flange
2. Secure the boot on the flange with said clamp
3. Slide this assembly over the clean axle
4. Put the clean cvj on the axle and put the ring on the axle
5. Put the grease on / inside the cvj on both sides
6. Slide the boot & flange up to the cvj and screw together
Done!
Anything wrong with this sequence?
6.
Old 10-06-2011, 05:28 PM
NoVector
NoVector's Avatar
^^^ Here's probably the best way:
Old 10-06-2011, 08:11 PM
jpitman2
jpitman2's Avatar
Re the post about balance issues with a screw clip (at least on the small boot) - one of my CV joint boots on the Suby is leaking, and until I can get it to service, I put a screw clip on it, and have not noticed ANYTHING at 65mph. At that small radius, it would take a fair bit of mass to produce much vibration IMHO.
On the large boot diameter, just maybe....
jp 83 Euro S AT 54k
Quick Reply: How to tighten this style CV boot clamp?
