928 Forum 1978-1995
Sponsored by: 928 Specialists
The Kraken - A Restoration & Modification Diary
Old 06-15-2011, 01:19 PM
  #31
Courtshark
Courtshark's Avatar
Considering fitting these 19s; the rears are SO close to fitting. As pictured, they have a 4mm spacer on the rear. They JUST clear the inside suspension and look pretty damn close to hitting the fender well on the outside. And that's without tires! I have a 12mm spacer I am going to try as well, but I fear that will rub the outside. They're 62mm offsets for the rears, 19 x 11. The fronts will fit without issue. 54mm offset, I believe. 19 x 8.5
I had to hold off on mounting tires to them until some issues related to the transaction were resolved (the one thing that went right yesterday), so the tires will go on (and thus the wheels on the car) hopefully Friday; if not Friday, then over the weekend probably.
Old 06-15-2011, 01:30 PM
  #32
Jadz928
Jadz928's Avatar
Nothing that a baseball bat won't take care of....
And when you have the body and paint work done, work in some flare and shape.
Old 06-15-2011, 01:33 PM
  #33
Courtshark
Courtshark's Avatar
Yeah, I'm considering rolling the fenders; might buy the proper fender rolling machine rather than taking an Easton to my car, though...
Old 06-16-2011, 02:16 AM
  #34
fbarnhill
fbarnhill's Avatar
Man, That car is really looking good. I am starting to get "brother envy". In my family it goes the other way around. I am always working on his car. I know you are anxious as heck to be driving that thing.
Best of luck,
Old 06-16-2011, 08:25 AM
  #35
nc_growler
nc_growler's Avatar
Feeling just a tad green myself!
Old 07-01-2011, 09:41 AM
  #36
Courtshark
Courtshark's Avatar
Been busy since my last post in this thread.
Power steering continues to be a battle. I think I need a new pump. The rack was replaced, as was the pressure line. The PO's mechanic used the wrong fluid once, so that may have killed the pump. The filter in the reservoir was completely blocked and crumbling, so I took out the filter entirely (recent Saabs use an almost identical reservoir with different inlets and outlets, and no filter). That stopped the cavitating noise. There's pressure from the pump, as fluid pumps out both the pressure and return lines when open while running. But there's still no power assist. Stay tuned there. Requires much brute force to turn in small spaces!!!
The shifter also decided to go a little nuts; the wobbly lower bushing or spring or both is causing the shift arm not to be able to disengage the gear sometimes, most often when trying to shift out of 4th. Short shifter is on the way, so I won't be driving the car much until that's in (two weeks)
Tried to install the 19" Cup 4s. The 285s look a little silly and the fitment is just too damn tight. They're 19x11s. I think they will fit, but the 285s look over stretched. They would look much better on a 19x10, so I will be looking for those; I found a set of the modular performance wheels I've got in 19 x 10, so I may go that route. Love the lok of the Cup 4s, though.
Otherwise installed/fixed:
AC (control head)
18" wheels
replaced tail light
replaced fog lens
front LED stripes (separate thread coming)
Momo steering wheel
hatch release (two nickels)
Old 07-01-2011, 09:50 AM
  #37
Leon Speed
Leon Speed's Avatar
Have you tried the rebuild kit (www.rennbay.com)?
Old 07-01-2011, 09:54 AM
  #38
Courtshark
Courtshark's Avatar
I've not, but I'm considering it. New pumps are pretty cheap, though, and with this one's already questionable past, I'm not sure I want to mess with trying a rebuild. I also saw another thread in my searching where the guy went through three "new" pumps before finding one that worked properly. That might drive me over the edge.
Still trying to decide what to do; will of course post here when I figure that out!
Old 07-01-2011, 10:11 AM
  #39
mickster
mickster's Avatar
I know this may start a flame war but there is always the Griffiths pump. Either way, I would fit the 91+ pump and lines to add higher pressure. It is supposed to make low-speed steering lighter (as in parking and tight maneuvering).
Old 07-06-2011, 12:38 AM
  #40
Courtshark
Courtshark's Avatar
7/4+5/11 update:
Finally got the time to seriously wash & detail the car. This is when you really discover all of the paint and body defects. And there are many. This car has been resprayed, and poorly. Going to try some Griots the next time around.
Did the interior today (7/5); gutted the carpet and tried various spot cleaners to remove what had to be years of dirt and whatever else accumulates on car carpet. The best result was using my Spot Bot carpet cleaner with Resolve laundry stain remover in the tank. Required much scrubbing after letting the stain remover sit on the carpet for about 5 minutes, but it looks MUCH better. Like new? Er, no. Better? Hells yes.
The passenger seat switches (12 way seats; rear two switches) are wonky, so those will need to be replaced.
Took the car out after all of this... and it responded by developing a crazy clunking sound from the left front wheel. Could be the wheel hitting the big red caliper; could be a loose brake pad, since it goes away undr braking. Not really sure. Too tired to investigate further right now. Gee thanks, Kraken!
Old 10-07-2011, 03:43 PM
  #41
Courtshark
Courtshark's Avatar
Wow, three months since my last update. Been busy with other things, I suppose, and out of town quite a bit. Right now, the car is immobile awaiting the return of my rear shift coupler from getting replacement bushings pressed in. Apparently this is an incredibly difficult and lengthy process. Once said process is complete, a short shift kit will be installed, hopefully sometime before 2012.
I bit the bullet and ordered the 19x10 rears of the Sport Edition Cup 4s last week, though because the car is immobile I haven't been able to see if they fit yet.
Also awaiting install: Roger's EIS; looks fantastic in the box. I also picked up a replacement power steering reservoir and pump rebuild kit.
The crazy clunking sound mentioned above turned out to be a loose lug nut. I always triple check whether I've tightened all the lugs, so hopefully it didn't work itself loose somehow.
Plus the passenger seat switches work... only with a passenger sitting in them! Neat.
Old 10-07-2011, 07:39 PM
  #42
SMTCapeCod
SMTCapeCod's Avatar
Owners Club has an easton rolling tool with custom 928 hub fitment as a loaner now....
Old 10-08-2011, 12:55 AM
  #43
Jadz928
Jadz928's Avatar
Gwen: It's not you, it's me.
George: You're giving me the "it's not you, it's me" routine? I invented "it's not you, it's me". Nobody tells me it's them not me, if it's anybody it's me.
Gwen: All right, George, it's you.
George: You're *damn* right it's me.
Old 10-11-2011, 01:05 PM
  #44
Courtshark
Courtshark's Avatar
Affairs of state take precedence over affairs of state. All pressing matters. Looks like a gift will arrive at my home today.
Old 10-11-2011, 01:40 PM
  #45
Courtshark
Courtshark's Avatar
The Kraken is (was) real!
http://www.escapistmagazine.com/news...nt-Kraken-Lair
Quick Reply: The Kraken - A Restoration & Modification Diary
