928 Forum 1978-1995
Sponsored by: 928 Specialists
CIS fuel distrib. individual fuel line adjustment HELP..Fixed?
Old 05-16-2011, 01:51 AM
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
Default CIS fuel distrib. individual fuel line adjustment HELP..Fixed?
I am tracking down a problem with my 82 Euro S that I have refreshed. It has not run right since I got it started the first time and I think I have traced it to different flow rates in the fuel injector lines from the fuel distributor. I am getting about half the volume in 4 lines(compared to the other 4) that I would like to increase the flow rate on. I have cleaned and rebuilt the fuel distrib. and replaced the diaphragm in it but the problem persists. I noticed these caps by the fuel heads. If I take the allen cap off there is an allen adjustment underneath. Does any one know how this is adjusted? Which way do you turn it to increase flow to that line output? Thanks- Gunar
Old 05-16-2011, 04:02 AM
dan928
dan928's Avatar
I have an '82 Euro S and my fuel distributor doesn't look like yours (no adjustments). Yours looks to me like a Mercedes fuel distributor.
Old 05-16-2011, 04:15 AM
Dave928S
Dave928S's Avatar
Here's a standard Euro S fuel distributor.
Edit: Original equipment on my 82S Australian delivered July build. 84's here were LH
Old 05-16-2011, 08:24 AM
porschedonald
porschedonald's Avatar
DD
Old 05-16-2011, 01:37 PM
gbgastowers
I used them to equalize the flow to each injector. With much trial and error and a lot of wasted fuel I have them flowing evenly. This may have been my"no power under load "problem as several cylinders were only getting half the fuel of the others. I will check in when I get it back together. Gunar
Old 05-16-2011, 01:51 PM
Landseer
Landseer's Avatar
This will be interesting.
Hope it works for you, Gunar.
Old 05-16-2011, 02:19 PM
gbgastowers
here is my scratch sheet- each row represents a test session of putting containers under each fuel line,jumpering the pump and holding the air plate down for a 12 count or more then measuring the individual amounts. I worked from the bottom of the scratch paper up and changed around some fuel lines on the way just to be sure it wasn't the line causing the low flow. The top row are the final results after a 15 count and pushing the plate with random pressure. 7 lines at 60cc and 1 at 57cc.
Old 05-16-2011, 04:16 PM
James Bailey
James Bailey's Avatar
I think Carl 928 MS was using one of the mercedes units at one time...
Old 05-16-2011, 04:28 PM
SeanR
SeanR's Avatar
Yous IS a proper Euro S fuel distributor, I've messed with quite a few of these and do not like them at all.
I think Porsche just popped whatever one it had in stock that day to our early cars.
Edit to add pic.
82 Euro S on left, 84 Euro middle, 79 US on right.
Old 05-16-2011, 05:50 PM
gbgastowers
It didn't fix it ...now it just sputters and won't rev. Maybe not getting enough fuel now. I have tried the A/F adjustment with no success. I am getting so tired of this.
Old 05-16-2011, 05:54 PM
993turbo
993turbo's Avatar
Originally Posted by SeanR
84 Euro middle
No 84 ROW (or euro as you call it) had a fuel distributor. They were LH-jetronic.
Old 05-16-2011, 06:02 PM
neilh
neilh's Avatar
Agree - 84 ROW - WP0ZZZ92ZES84---- LH-jetronic
Old 05-16-2011, 06:20 PM
LT Texan
LT Texan's Avatar
Originally Posted by gbgastowers
here is my scratch sheet- each row represents a test session of putting containers under each fuel line.
Under each fuel line or injector?
Old 05-16-2011, 06:31 PM
gbgastowers
This session was flow under the fuel line(unscrewed from injector). I noticed the streams looked different is what led to it.
Old 05-16-2011, 08:20 PM
gbgastowers
what should I do now? I am thinking about turning it back to where they were because it ran better then. Maybe the ones that were really flowing were the only ones with high enough pressure to run the car and now they all don't have high enough pressure. I guess I should do a volume and spray pattern check with the injectors in the containers.
Quick Reply: CIS fuel distrib. individual fuel line adjustment HELP..Fixed?
