928 Forum 1978-1995
Sponsored by: 928 Specialists
Wiper motor overhaul
Old 03-05-2017, 07:46 PM
  #31
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Is Porken's PDF located anywhere, its a dead link in this thread.
Old 03-05-2017, 08:51 PM
  #32
PorKen
Inventor
PorKen's Avatar
Copy the link then change members.rennlist.ORG to .COM - recent unresolved Rennlist server issue
(WiperMotorRepair.pdf) 3.7Mb
Old 05-19-2019, 08:34 AM
  #33
merchauser
merchauser's Avatar
did anyone ever try the ceramic bearing?
Old 05-19-2019, 01:11 PM
  #34
Hey_Allen
Hey_Allen's Avatar
Thanks to you reminding me of this thread (and needing to get my wipers working anyhow) I've just ordered a pair of ceramic hybrid bearings, and will be installing one soon.
Here's to hoping that I don't shatter the ***** while doing so, but it comes with a spare if I do!
edit:
Here is the part that I ordered, if anyone is interested.
Amazon Amazon
Old 05-19-2019, 07:15 PM
  #35
merchauser
merchauser's Avatar
edit:
https://www.amazon.com/6000-Ceramic-.../dp/B076T7T385
please post your results. is the idea behind the ceramic bearing that high speed will run faster, or another reason?
Old 05-20-2019, 04:38 AM
  #36
Hey_Allen
Hey_Allen's Avatar
That was the initial reason proposed a while back, but I bought the hybrid bearings just for the added resistance to any corrosion fouling them over time.
Not having any metal ***** in the bearing, they can't rust. The races still might if the seals get compromised, but it's one less failure point, and they weren't that much more expensive than a decent quality all metal bearing.
I won't be able to give any evaluation of them being faster or not as mine are not working at all, since this car had been neglected and stored outside for ~10 years before I was saved it from a scrapper friend before he got around to it.
Old 06-16-2019, 11:40 AM
  #37
merchauser
merchauser's Avatar
Originally Posted by PorKen
Mark the position of the slot on the plastic set screw and remove.
Ken, cannot get my plastic set screw to budge. suggestions?
Old 06-19-2019, 11:23 AM
  #38
merchauser
merchauser's Avatar
I have buggered yup the set screw, now what? the softness of the plastic head gave way when trying to remove. (I know I can just buy another, but this one can be fixed)
what exactly does that screw do, and can I replace it with something else? as per Porken, it appears it needs to be removed in order to drive out the armature? what is it plastic?
Old 06-20-2019, 06:36 PM
  #39
Manuel928S4
Manuel928S4's Avatar
Default Didn't do much difference
I tried the ceramic bearing about 2 years ago (forgot to post that here woops) and it didn't do much of a difference. Maybe its more quiet, but i felt no difference in wiper speed.
Old 12-22-2019, 03:06 AM
  #40
jpitman2
jpitman2's Avatar
The speed is only changed by the angle of the brushes other than the 2 at 180degrees. My wiper motor is well over to the car's RHS, which is not as shown in PET? Hopefully that will make removal easier when the time comes?
Attachment 1344261
jp 83 Euro S AT 57k
Old 08-29-2024, 10:12 PM
  #41
928Collector
928Collector's Avatar
1. Anyone have the link/write up on the windshield wiper motor repair instructions? It looks like that website page is no longer.
2. My wipers move about 1/4 inch up and down so hopefully the motor + bearing are good. Short of the wiper motor refurbishment, if anyone has any thoughts why the wipers aren't sweeping all the way across the windshield it would be much appreciated.
Old 08-29-2024, 10:26 PM
  #42
PorKen
Inventor
PorKen's Avatar
There is a PDF of the missing photos above
Quick Reply: Wiper motor overhaul
