928 Forum 1978-1995
Sponsored by: 928 Specialists
Replace Head Studs?
Old 06-18-2010, 06:52 PM
  #46
jon928se
jon928se's Avatar
I would say studs everytime, irrespective of wether they are designed to yield or not and wether they are replaced every time or not.
For one reason. Studs are screwed into the block with no load on them. Bolts are screwed into the block with load on them. There is lots of chance that the bolt threads could gall against the alu threads in the block while being tightened and damage the threads in the block = mucho problemo.
Old 06-18-2010, 07:57 PM
  #47
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,455 Likes on 1,460 Posts
Possible, except I've done many, many of these engines and never had a head bolt pull the threads or gall them.
The blocks that get Nicasil coated get bead blasted and then "soaked" in acid before they plate them. When they come back, it takes hours (ask Rob Edwards) to clean the grey "muck" out of the head bolt threads, before we can put them back together. We have to run thread chasers multiple times down each hole to get them ready to accept hardware. They don't even have problems with bolts....so I don't worry too much about this.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 06-18-2010, 08:13 PM
  #48
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
hours
Yeah, like half a day. Still have bad dreams about it, and what you did to that poor shirt with the ATF.
New bolts on my motor. I have the old bolts, which I had replated so they're good as new. Anyone want 'em?
  #49
SeanR
SeanR's Avatar
I'm glad you guys hang out here, such an amount of information.
So, let's say that I'm building a 5.0 block, stock internals, for boost. Do you all suggest using studs or sticking with the bolts?
Old 06-18-2010, 10:18 PM
  #50
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Aside from the fact that "boost" and "928" should never be used in the same thought process...
With a boosted engine, you want to have really good "clamping"...hot or cold....or the head gaskets will have a tougher life.
New head bolts will do that...they have to be very elastic to stretch as much as they do and not yield.
Mike Simard also has done the calculations so that the material he makes his studs out of "stretches" enough to clamp the head gasket properly when the engine is both hot and cold.
Pick one.
Old 06-18-2010, 10:22 PM
  #51
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Try and picture what his face looked like...as he looked down the blower nozzle to see what was happening at the bottom of the stud hole. I think we had to play "seeing eye dog" and guide him to the bathroom, as I recall.
I was going to mention not to do this....but somehow got distracted.
Old 06-18-2010, 10:41 PM
  #52
ptuomov
ptuomov's Avatar
Why not? Too much hp/$ for your taste? ;-)
  #53
blown 87
Rest in Peace
blown 87's Avatar
Sounds like he got a face full of crud.
Old 06-18-2010, 10:53 PM
  #54
SeanR
SeanR's Avatar
Pick one.
Thanks for the info. I know what you did there, and for some reason I agree.
Old 06-19-2010, 11:35 AM
  #55
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
I'd rather end up with a face full of crud from Greg's shop than Rob's shop
Old 06-19-2010, 11:53 AM
  #56
blown 87
Rest in Peace
blown 87's Avatar
Good point, and Yuck, just the thought of that.
Old 06-19-2010, 05:33 PM
  #57
Formula94lt1
Formula94lt1's Avatar
What I am getting out of all this is replace them, whether they are bolts or studs, with either stock parts or Simard's parts. If stock bolts or studs then torque 20nm followed by 3 series of 90 degree turns, seems to be the proper way of doing this. I'm sure Simard has his own way of using his studs.
Correct?
Trying to bring all of this together in an unconfusing manor. Thanks guys!
Old 06-20-2010, 06:02 PM
  #58
Formula94lt1
Yes, no?
Old 06-20-2010, 08:15 PM
  #59
Hilton
Hilton's Avatar
Originally Posted by Formula94lt1
Yes, no?
Sounds like replacement is mandatory to me - check the workshop manual and tech bulletins for the correct torquing spec. I vaguely recall some 928's require three 90 degree turns, some only two, depending on studs/bolts/heads.
Old 06-20-2010, 09:49 PM
  #60
blown 87
Rest in Peace
blown 87's Avatar
I am going to start replacing bolts on all the head jobs we do at the shop, not just on the ones that call for it.
What I am getting out of this is that you can not get the clamping force that the engineers wanted when using old bolts/studs, regardless of the method used to tighten them, IE simple torque or torque plus degrees.
I have only had two comebacks on head gaskets in the last 17 years and we have done countless ones, if I had to guess the number is over 200, but I wonder if the two that I did have problems with were related to using old bolts.
One was a Toyota R-22 and the other was a Nissan something that I can not remember, this does not include any kind of supercharged cars with tuning issues, those do not count IMHO.
Quick Reply: Replace Head Studs?
