5 speed clutch master cylinder differences FYI
Team Owner
This is for the clutch operated car owners.
I have been doing a few clutch hydraulic replacements and I have seen a few times so far where the new master cylinder bore is about 1/4 inch shorter than the old part. ( the pistons however are the same dimensions)
I think others have also come across this same problem.
This will prevent the pedal from traveling the distance it used to and possibly cause a dragging clutch system as there wont be as much travel for slave actuation.
So if your replacing the master on the clutch make sure to check the distance of the old and new units if you do in fact have a shorter bore one of the remedies is to remove circlip and the piston from the bore and remove the same amount from the tip of the piston , make sure to also cut a slit into the end so that fluid can still flow at full travel. Good luck, Stan
Man of many SIGs
I made a thread about this a couple of months ago. I had some pics and measurements as well I believe. You can cut part of the spring guide off to gain back some travel. Thats what I had to do and it has worked perfectly ever since. I'll try to dig that thread up later and post it here for a cross reference.
Team Owner
Cool Fabio, I posted this as someone else has a few questions about installing clutch Hydraulic replacement parts
Former Vendor
I had same problem with dragging clutch issues.After bleeding,adjusting "h" pieces on int.plate,swapping MC guts,I trimmed off the piston to get more stroke.Solved the problem!! One thing is the first try I went too far and had the piston overtravel so brake fluid ended up going behind the seal and pumped into the cockpit upon pedal release.
Team Owner
Thats a good point you want to measure first to make sure that the piston doesnt go past the fluid feed
Man of many SIGs
Heres the other thread w/ pics and measurements.
https://rennlist.com/forums/928-foru...=clutch+master
myself I did this by opening the slave cylinder bleed and adjusting so that gravity did not allow fluid to run out & then turned it back a half turn.
Marton
Man of many SIGs
Team Owner
Marton this is not a clutch pushrod adjustment .
The part that gets modified is on the inside of the clutch master cylinder, its the very tip of the piston that has to be trimmed shorter to give the full throw of the older deeper bored cylinders.
Pay attention to the rear seal on the piston , if you remove too much from the piston it will go past the internal fluid feed and thus fluid will leak out the rear of the clutch master cylinder
Team Owner
for those that might like to review this info,
here is a bump
here is a bump
Thank you Stan.
