928 Forum 1978-1995
Sponsored by: 928 Specialists
Current draw on radiator fans
Old 04-05-2003, 12:23 PM
Paul D
Paul D's Avatar
Post Current draw on radiator fans
I'm replacing my belt driven fan with the S4 electric fans. Anybody have an idea how much current both fans will draw? Or, what is the fuse rating on the power for the fan circuit? Thanks in advance!
Old 04-05-2003, 02:45 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Post
The fans are fused separately - EACH fuse is rated at 30 amps.
Old 04-05-2003, 02:47 PM
morganabowen
morganabowen's Avatar
Post
I can't answer your questions, but I did the same thing last summer, and my '82 runs cool all the time. One of the best investments I've made in my shark.
Larry
1982 Porsche 928
BADD928
Old 04-05-2003, 03:18 PM
Mark
Mark's Avatar
Post
I'm interested in doing this also...
1 - Where did you guys get the fans?
2 - How much?
3 - Is it an easy 'bolt-on' procudure?
4 - Where did you tie in the electricals?
Old 04-05-2003, 03:33 PM
Paul D
Paul D's Avatar
Post
Thanks for the info Wally. Looks like I better get some garden hose diameter wire for each of these fans. I bought the fans and the shroud off e-bay. I've seen them for sale anywhere between $100 to $200. I'm thinking about buying one (or 2) of these <a href="http://www.perma-cool.com/Catalog/Cat_page19.html" target="_blank">Thermal switches</a> . I'm planning on tapping into the (+) jumper terminal under the front hood for power. When I finish (maybe next month) I'll post some pic's. I'm hoping my alternator will supply enough current for these puppies. Thanks again!
Old 04-06-2003, 10:53 PM
chris928
chris928's Avatar
Post
The trimline fans (http://www.flex-a-lite.com/auto/trimline.htm)use less than 10 amps. You can use a 12" and a 10" side by side for less than 20 amps total.
The 928 is a very well engineered car and you should use a well engineered fan controller as the original designers did.
A switch will work, but not too well, especially at 170 deg.
Flex-a-lite has just come out with a very nice controller which has an adjustable set point. When the set point is reached, the fans come on at 60% (very quiet, cant hear them). As the temperature rises beyond the set point the fans speed up until they reach the 100% speed. It also has aftercooling for when the car is shut down, the fans run for 30 seconds to cool the engine comartment. My wiring harness told me that it likes this feature. All your other rubber components will agree. There is also an input for A/C which will tell the fans to come on if the A/C is running. It will also run both fans. There are other features, too, such as a manual override.
The other option is to use the controller off of an S4. It's a very nice unit.
Good fan controllers are hard to find. The flex-a-lite just came out in february. Before that, I couldn't find a decent aftermarket one and started designing my own. Now it seems I won't have to.
Quick Reply: Current draw on radiator fans
