928 Forum 1978-1995
Sponsored by: 928 Specialists
Broken Bolt & broken EZ out!!!!!!!!!!! HELP
Old 06-22-2006, 09:32 PM
  #31
RngTrtl
RngTrtl's Avatar
I have used an easy out many times successfully....however, all instances were pertaining to a bolt being sheared off leaving only the stub sticking out. The bolt was not "seized". This is what easy-out are supposed to be used for i think, not for bolts that are broken from excessive torque during removal because the threads were seized.
Old 06-22-2006, 10:39 PM
  #32
IcemanG17
IcemanG17's Avatar
Originally Posted by Bill Ball
Brian:
This is a 6mm bolt (10mm head), right? I have Time-Serts. Come on over on Sunday. Kirt and I will be servicing his AC starting at noon, and we can insert that hole. Since the hole is shallow it may take some modification of the insert, but I'm sure we can fix this good as new.
Bill
Yes its a 10mm head bolt (at least the original one was)..the new bolt is a touch bigger SAE with coarser threads....I will try the inserts if this bolt doesn't hold.....I really haven't driven the car since I tapped new threads.....a couple spirited drives should test its clamping ability.....
Old 06-23-2006, 10:20 AM
  #33
Imo000
Captain Obvious
Super User
Imo000's Avatar
As far as the treads of the bolt go, was probably a 6mm bolt with a 1.5mm tread pitch.
Since you tapped a new tread and using a new bolt, I don't think there will be a need to any furhter repairs. I'm confident it will hold. The dust shield is light and there aren't any real forces acting on that bolt.
Old 06-23-2006, 11:36 AM
  #34
IcemanG17
IcemanG17's Avatar
I was thinking the same thing.....the only real force on that bolt (other than vibration) is the slight bowing of the dust cover (not enough to hit the rotor)...maybe 1/2 inch....but you could easily press it back into place with a finger....plus you can see the locktite in the picture...I put a bunch on there and was careful not to over-torque the new bolt and strip it!!
Quick Reply: Broken Bolt & broken EZ out!!!!!!!!!!! HELP
