Difference between tranny oil and engine oil coolers?
Trying to make sense of what is advertised out there. am I correct to assume that the engine oil coolers are header style (but can also be used for transmission fluid cooling), while transmission oil coolers are the trombone style, but not recommended for engine oil cooling?
If anyone could confirm or shed light on preferred or most efficient style heat exchangers for either application, it would be greatly appreciated
Thanks in advance
Tarek
Thanks in advance
Tarek
When I had my radiator fiasco a few years ago, I was told that the coolers in the end tanks were identical. The oil cooler and the transmission cooler are the same and as such are interchangeable. Least that's what I was told.
N!
N!
Rennlist Site Sponsor
If you are talking about aftermarket coolers, there are several types available - tube and fin, plate and fin, etc.
One major difference - coolant (radiator) and transmission coolers only have to stand 25 psi, whild oil coolers have to be good for 125 psi.
Incorrect, per Wally... see post #3
N!
N!
I would certainly recommend going with a plate and fin type cooler. From my experience they hold up much better and are less susceptible to damage than a tube and fin unit. BTW, most plate and fin coolers are also rated for higher pressures, eliminating confusion between trans fluid / oil applications.
Thanks for the clarification everyone. Yes Wally, I was referring to aftermarket coolers. As far as pressure ratings are concerned, the aftermarket manufacturers don't seem to advertise them much. Some claim both applications and others offer separate products for the different applications.
But as TopDownL79 is pointing out, it may be safe to stick with the plate and fin type.
I am however, still confused about header style versus continuous, trombone style
