928 Forum 1978-1995
Sponsored by: 928 Specialists
The Twin Screw Thread
Old 12-12-2005, 09:57 PM
  #91
BrianG
BrianG's Avatar
Thanks very much Daryl, Mike and Jim. This is coming together nicely. One last fuel system question, if you would.
If you look at Rich's '85 car with the custom fuel rail logs, you will notice that he deleted the fuel dampeners. I plan to use the same logs. What is the consensus on the need for the dampeners?
Old 12-12-2005, 10:00 PM
  #92
BrianG
BrianG's Avatar
Next issue......... The '86 throttle body I got from 928 Int'l does not have the Closed/WOT switches on it. I'm not sure I can even see where they would mount.
I gather I need them?
Does anyone have a picture of the throttle body with the switches mounted?
It would help to decide what bits I need to order.
Old 12-12-2005, 10:05 PM
  #93
heinrich
928 Collector
heinrich's Avatar
You need the S4's.
Old 12-12-2005, 10:12 PM
  #94
Ketchmi
Ketchmi's Avatar
Uhh Mike, the ARRFPR does indeed decrease fuel pressure...I have run as low as 25psi on the 89' with one. (with 30# injectors of course)
Old 12-12-2005, 10:22 PM
  #95
mspiegle
mspiegle's Avatar
The BEGI2025 unit that 99% of the SUPERMODEL kits use does NOT decrease fuel pressure. IT IS IMPOSSIBLE.
The unit works in tandem with the existing fuel regulators. The ONLY way you can decrease the fuel pressure is to reduce an in-line restriction. Since a restriction is already imposed by the stock regulator - it is physically impossible for the BEGI RRFPR to lower fuel pressure. It can only increase the fuel pressure by adding more in-line restriction.
Please do not confuse people on this thread.
Old 12-12-2005, 10:24 PM
  #96
Jim_H
Jim_H's Avatar
I'll get you one, Brian. I don't think the dampeners are required but hopefully somoene else can chime in to confirm
Old 12-12-2005, 10:25 PM
  #97
BrianG
BrianG's Avatar
Originally Posted by heinrich
You need the S4's.
Are you saying that the mounting will be intuitive?
Wanna bet!!
  #98
mspiegle
mspiegle's Avatar
You need the throttle switch from an 85/86 car if you don't want to do any modifications. You may use an S4 switch if you drill a hole through it (VERY carefully) and mount it backwards. The reason is because the throttle opens differently on an S4.
Old 12-12-2005, 10:26 PM
  #99
mspiegle
mspiegle's Avatar
You need the S4's.
You can only use the S4 switch if you physically modify it to mount backwards on the throttle body.
Old 12-12-2005, 10:28 PM
  #100
Jim_H
Jim_H's Avatar
Thanks for that Mike. I didn't remember use the S4 switch
  #101
mspiegle
mspiegle's Avatar
The fuel dampers are REQUIRED. They are there for a reason. Fuel injector pulses will screw around with the fuel pressure. You may find yourself running lean in certain cylinders if you leave these out. As each injector opens, you get a drop in fuel pressure. The damper eliminates this.
Old 12-12-2005, 10:29 PM
  #102
Jim_H
Jim_H's Avatar
Just get the 85-86 switch.
Wanna bet!!
Old 12-12-2005, 10:33 PM
  #103
mspiegle
mspiegle's Avatar
Just for clarification, regarding fueling requirements for the '87+ cars:
The ONLY kit that may run without 30# injectors for an '87+ car is the basic 4psi stage1 jag/eaton kit. For anything more than that, USE 30# injectors with 85/86 regulators.
Old 12-12-2005, 11:11 PM
  #104
CMW
CMW's Avatar
Yep
Old 12-12-2005, 11:20 PM
  #105
FlyingDog
FlyingDog's Avatar
Mike, the BEGI is an FMU. An RRFPR will reduce fuel pressure like any fpr. Also, Tony is running 24lb injectors with more than the basic 4psi kit. IIRC, his 30lb injectors wouldn't idle right, but at least one was bad.
Quick Reply: The Twin Screw Thread
