Cheap Axle Alternative
Old 10-20-2012, 10:23 PM
  #136
hot-J
hot-J's Avatar
Installed one 2k ago. Running fine, and I've been beating the crap out of it.
hot-J is offline
Old 10-20-2012, 11:09 PM
  #137
CyCloNe!
CyCloNe!'s Avatar
^ what are you beating it with? a midget
CyCloNe! is offline
Old 10-21-2012, 12:37 AM
  #138
hot-J
hot-J's Avatar
Hey, Midgets need love too.......
hot-J is offline
Old 11-14-2012, 03:44 PM
  #139
ibtisam.jawad
ibtisam.jawad's Avatar
For those worried about angles ...
01-98-5084-B EMPI OFF-ROAD T-2 CV JOINT ONLY, 100mm, EACH $ 46.95
^ Max angle of 25 degrees
01-87-9469-B EMPI 930 CV JOINT ONLY, 108mm, EACH $ 51.95
01-87-9469-K EMPI 930 CV JOINT & BOOT KIT, 108mm, EACH $ 75.95
^ Max angle of 21 degrees - made for 930, if something can be done to adapt to the 108mm O.D. since 944s use 100mm O.D., if I'm not wrong
Plus many more options here... http://www.dansperformanceparts.com/...susp%20IRS.htm
Just found the above link on thesamba.org or something similar. Just copying someone else's research here for reference.
ibtisam.jawad is offline
Old 11-15-2012, 12:16 AM
  #140
Turbodan
Turbodan's Avatar
mine have been fine with about 6 or 7 hard trackdays at Mosport.
Turbodan is offline
Old 12-15-2012, 08:06 PM
  #141
eclou
eclou's Avatar
Received 1,165 Likes on 574 Posts
just ordered a pair. I killed my passenger side axle the last track outing. Heard a bang then something that sounded like a woodpecker. Found almost every bolt on the transaxle side of both axles was loose or out completely. Axle itself appears intact so probably the inner cage of the CV is toast. This is a great find BTW
eclou is offline
Old 12-16-2012, 05:45 AM
  #142
shortyboy
shortyboy's Avatar
What type of bolts do the axles come with?
shortyboy is offline
Old 12-16-2012, 01:56 PM
  #143
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
When you say, fits later models, doe sthis mean it will bolt right up to a '86 851?
hosrom_951 is offline
Old 12-16-2012, 02:19 PM
  #144
refresh951
refresh951's Avatar
Yes
refresh951 is offline
Old 12-16-2012, 04:35 PM
  #145
eclou
eclou's Avatar
As an update I pulled both my axles last nite and inspected them to look for broken cages or wear. No obvious signs of problems and they articulated smoothly. The passenger transaxle side CV was almost bone dry though. I re-greased it and swapped the axles L to R to reverse the stress on the units. Went to the track today and my noise was gone for now
eclou is offline
Old 12-16-2012, 06:17 PM
  #146
mikey_audiogeek
mikey_audiogeek's Avatar
Hi, what's your thinking behind this?
(Back when I was crewing, our driveshafts were marked L and R so we couldn't fit them in the wrong side.)
My understanding is that driveshafts don't like stress reversals, it's usually considered best to keep them loaded the same way. Otherwise they fatigue more rapidly.
IIRC, Carroll Smith mentions this in "Engineer to Win".
Of course if CV's are more likely to fail than the shafts, that's another story!
Cheers,
Mike
mikey_audiogeek is offline
Old 12-16-2012, 06:21 PM
  #147
eclou
eclou's Avatar
Cheers,
Mike
I made the assumption that the noise I heard was due to binding in the CV, and that the wear would be early and not catastrophic - no visible signs. By reversing the torque I was hoping that the worn axle may have enough life left for 1 track session (today) without failing. I have already ordered new EMPI units. It worked for now
eclou is offline
Old 12-16-2012, 08:15 PM
  #148
xschop
xschop's Avatar
4340 alloy axles are less prone to the torque twist memory and can be flipped.
xschop is offline
Old 12-28-2012, 06:49 PM
  #149
eclou
eclou's Avatar
well I got mine and tried to install them today (EMPI). Mine is an early offset 86 and they don't fit. They are maybe 1/4" too wide in the axle to clear the mounting cups. I can attach the outer CV joints to the wheelside but the length of the actual axle will not clear the cup on the transaxle. It is a smidge too wide.
eclou is offline
Old 12-29-2012, 01:40 AM
  #150
CyCloNe!
CyCloNe!'s Avatar
Robstah has them on his 86 951 early offset, maybe he has suggestions to help. I plan to get these myself this spring.
CyCloNe! is offline
Quick Reply: Cheap Axle Alternative
