FS: PARTING 86 944na with 924 TURBO•951 GOODIES!
Hello Good People,
After many years of enjoying the 944 I have decided to part it out in hope of raising funds to promote literacy for children and adults.
Here are the parts available. If your looking for something that isn't listing than drop me a message.
Thank you all!
• 968 Front sway bar 26.8mm $175.00
• 944 Small sway bar $75.00
• Rear 18mm sway bar with linkage $160.00
• 968 Outer door handles $175.00 SOLD
• 944 Inner door handles with Porsche crest $60.00 SOLD
• 924 OEM Turbo vented nose panel (vinyl wrapped) $275.00
• 944na Hood $130.00
• 944 Hood Shocks $20.00 SOLD
• 924 OEM Turbo hood (vinyl wrapped) $375.00
• 944 Scissor Jack with handle $40.00
• 944 Inner Fender Wheel Plastic Lining driver side $90.00
• Turbo rear valence $150.00 SOLD
• Doors $75.00 each
• GT Euro headlights with Rennbay relay harness $350.00 SOLD
• Dino steering wheel with quick release hub $175.00 SOLD
• 944na engine $650.00
• 944 Coolant Hose Kit $45.00 brand new unused SOLD
• 944na Headlight Covers $25.00
• 944na Fender $115.00 Driver side
• 944 dashtop cover $45.00 SOLD
• Engine Computer $160.00 SOLD
• 944 Fusebox with lid $90.00
• 944 Fuel rail with Turbo injector with FPR $150.00
• 944 Heater Valve with houses $40.00
• 944 Front Wiper Motor $50.00
• 944 Front Wiper Arms $20.00
• 944 Wiper/Turn Signal Assembly $40.00
• 944 J-Boot $25.00
• 944 Hatch Button $20.00
• 944 AC Compressor $60.00 SOLD
• 944 Blower $55.00
• 944 Rear Hatch Motor and Assembly $50.00
• 944 Altitude Correction Sensor $15.00
• 944 Oil Dipstick $15.00
• 944 Intake Manifold $40.00
• 944 Throttle Body $35.00
• 944 Brake Master Cylinder with expansion tank $40.00
• 944 Front Door Seals $30.00
• 944 Radio Antenna Amplifier Booster $20.00
• Idle Stabilizer Valve with hose and bracket $55.00
• Gauge Cluster with white face $160.00 SOLD
• Gauge Cluster Bezel $35.00 SOLD
• A-Pillar Dual Gauge pod $55.00 $80 with gauges and all hardware SOLD
• Center Console Burgundy $50.00 SOLD
• Rear Seats Burgundy $150.00
• Crank Speed Reference Sensor $20.00 brand new unused SOLD
• Sunroof Switch $25.00
• Flipkey $25.00
• Rennbay Air/Fuel brand new (replaces your clock) $25.00 SOLD
• Newer model sun visor clip $11.00 both SOLD
• Polyurethane Steering Rack Bushings brand new $10.00 SOLD
• Voltage Regulator new $8.00
• Innovative AutoSports Performance Chip new $18.00 SOLD
• Front Wheel Bearing Kit $30.00
• Rear Tail Light Assembly $55.00each
• Rear Side Marker Light $25.00each
• Front Side Marker Light $25.00each
• Fan Relay $75.00
• Lart's Custom Turbo Braided Fuel Lines $50.00 SOLD
• 17" turbo twist rims with Hella digital pressure display $600.00
• Wilwood Front Calipers $475.00 with brand new brake pads SOLD
• Front bumper pads $45.00 each
• Front bumper $180
• Rear bumper $180
• Alloy Lug Nuts Silver Set: 4 new and 15 used - $25.00
• Alloy Lug NutsBlack Set: 16 used - $25.00
• Porsche 944 Protective Plate Part Number: 944.504.167.00 $45.00
• 944 Workshop Manual Volume I Engine $35.00
• 944 Workshop Manual Volume IV Electrics $35.00
• DME/Fuel Pump Relay - brand new unopened $10.00 SOLD
• Flasher Relay - brand new unopened $5.00
• Interior/Luggage Lamp with 3 LED bulbs - brand new unopened $10.00 SOLD
• Booster Check Valve with gasket - brand new unopened $35.00
• Manson's Solid State Battery Isolator $45.00
• Weltmeister Front Control Arm Bushings, PB-1030, 944/944S2, (2/85-91) Brand New $20.00 SOLD
• Headlight Switch $17.00
• Reverse Brakelight $20.00
• Dimmer and Fog Light Switch both $10.00
• Window Switches and Bezel all $45.00 SOLD
• 924S 944 Sunroof Hinge Latch and 3 Metal Bracket Set $65.00
• 968, 944 NA & Turbo, S2 Sunroof Wind Deflector with front striker plate $35.00
• 944 951 Turbo S S2 Radiator Fan $75.00 SOLD
• 944 Vacuum Canister $10.00
• Radiator cooling fan resistor $10.00
• Plug wire/Distributor cap/Distributor rotor $40.00 less than 7months old SOLD
• Alternator with 14.5 adjustable voltage regulator $35.00 SOLD
• Ignition coil with cap and bracket $20.00
• Fuel rail gauge and adapter $10.00 SOLD
• Sunroof Assembly **everything needed** $99.00
• Escort passort SR1 Radar Detector $150.00 SOLD
• Kenwood KVT-617DVD Stereo Receiver $250.00
• Kenwood KNA-G510 Garmin GPS $145.00 SOLD
• Kenwood KHD-C710 Music Media HD $160.00
• Kenwood KAC-959 Car Amplifier $75.00 SOLD
Thank you all!
• Doors $75.00 each
• 944 J-Boot $25.00
• 944 Blower $55.00
• Flipkey $25.00
• Fan Relay $75.00
• Front bumper $180
• Rear bumper $180
Yes Michael, a great-n-fun car indeed!
We tried to auction her but ran into some thick red tape.
In this multifaceted approach I get to teach my daughter about commitment and sacrifice through my actions. Trust me she will be helping me break the 944 down. She also will be learning how to turn a wrench and be empowered to do what any boy can do skill wise.
The short game is to raise money for the charities much believed in.
The long game is to establish a setup where companies can donate parts and the young people learn how to rebuild cars, bikes, boats, etc. Once a vehicle is completely rebuilt it gets auctioned off and the process repeats itself thus helping create more individuals with literacy. If I can put this into motion with my 944 than that’s a good thing - total recycle!
Its another approach that can and will work. There are lots of ways to helping address the issue besides spending copious hours in front of a book. I could go on but I hope you have a better understanding of the objective.
Ya... she was the car I saw when I was 16yrs, I later got here and it turned into a romantic 24yr daily driver. I'll get another one
