Problem with early style front struts
Old 10-16-2016, 12:16 AM
ClassicStyle
ClassicStyle's Avatar
Default Problem with early style front struts
While taking apart my failed and rusted early-style front struts, the cartridge came apart leaving me with just the shock absorber cartridge outer skin stuck inside the strut body.
I've beat the eve​​​​r loving snot out of the inner housing you see in the photo trying to get it out, and so far to no avail.
I'm open to, and pleading for, ideas on how to get it out of there. I see no means of retention, so I'm assuming it's just rusted in there like the top bushing was when I removed the threaded cap...
Thanks! ​
Old 10-16-2016, 12:59 AM
V2Rocket
Rainman
V2Rocket's Avatar
Drill a hole in the bottom of the strut and stick a punch through?
Old 10-16-2016, 01:25 AM
ClassicStyle
Definitely considering it, but wanted to consult the RennGurus before doing anything that drastic. I'm also a little concerned I'll just end up punching a hole through the bottom of the cartridge skin, given that I was able to stretch open the top of the cartridge without getting the skin loose.
Any other ideas (hare-brained or rational) I can add to the list of options?
Old 10-16-2016, 02:46 AM
AZ520
AZ520's Avatar
Heat might help! Propane torch the housing!
Old 10-16-2016, 11:35 AM
V2Rocket
Rainman
V2Rocket's Avatar
find a plumbing supply place (ferguson, if you have one local) and ask for an "internal pipe wrench"...maybe one you can rent?
Old 10-16-2016, 12:05 PM
Noahs944
Noahs944's Avatar
Replace the entire strut housing, both sides at same time.
Old 10-16-2016, 01:23 PM
snb13
snb13's Avatar
If you punch a hole in the bottom of the strut housing, won't that permanently drain it of oil?
Old 10-16-2016, 07:41 PM
tempest411
tempest411's Avatar
The strut housing do not contain oil, they just hold on to the strut cartridge, which contains the oil.
Old 10-16-2016, 08:40 PM
kevin12973
kevin12973's Avatar
I cut the cap off the bottom then punched the old cartridge out. Then welded the cap back on and pained it.
Old 10-16-2016, 09:23 PM
AZ520
AZ520's Avatar
FiX it!
Old 10-16-2016, 09:26 PM
marc abrams
marc abrams's Avatar
Actually you are supposed to fill the strut housing with oil before inserting the cartridge. Help's with heat transfer and rust.
Old 10-16-2016, 09:30 PM
V2Rocket
Rainman
V2Rocket's Avatar
^^heard about doing that but...not required.
Old 10-16-2016, 11:04 PM
snb13
snb13's Avatar
They do. If yours is empty, it's not supposed to be.
Old 10-17-2016, 12:15 AM
Noahs944
Noahs944's Avatar
That's interesting! What type of oil? Hydraulic I assume.
Old 10-17-2016, 12:31 AM
V2Rocket
Rainman
V2Rocket's Avatar
Think I read a Porsche bulletin/note that said to use ATF.
Quick Reply: Problem with early style front struts
