FS: 14" slim radiator fan and 944 rad shroud
Rainman
I bought this fan from eBay and made a shroud plate for it as an experiment to see about getting some working space in the engine bay vs the stock fans.
Decided to try something else so I don't need this anymore. Worked well enough for the year or so I've been running it.
The shroud bolts up to the 944 radiator fan nuts...as you can see the fan is larger than the rad is tall so you'll need to figure some way to block that portion off on your car.
Comes with a wiring harness and HD relay...I had it set up to use the OEM 944 fan wiring to trigger the relay, then ran a new power wire from battery to relay. This runs the fan at full power, and takes the amp load off the old factory wiring. You could just run this fan off stock wiring if you wanted though.
Fan was like $40 on eBay plus my time+materials for the shroud...would like to get $50 + ship for this if possible.
