How much does the tar mats weigh? I found out!
I unfortunately didn't weigh everything because I've been slowly chipping away at this project for a while and wanting to drive the car keeps getting in the way of finishing it.
Tonight I sat and scraped out the entire drivers side floor pan. It was the last bit of it I had left!
Anyway, I remember seeing someone ask how much all the tar mats weigh and whether it is worth it to spend the time removing them.
6lbs 11oz for the driver floor pan.
I would assume that each floor pan accounts for roughly 1/3 of the tar mats in the car. The tar mats in the rear making up the last 1/3. Given that, you are looking at saving around 20-ish pounds by scraping the tar mats off.
Would I do it again just to save 20lbs? Probably not. At least not until I was to the point where that 20lbs would actually make the difference in whether or not I could win a race.
Now it's time to scrape all the stuck on glue and adhesive off! Fun!
Ya that's a good call.
I vacuumed up as much as I could after I pulled up the carpet padding that was for some reason really wet. I wonder what all the carpet padding weighs? especially when it's all wet lol.
The carpet padding leaves a nice mess behind too thanks to the kind gentleman at the Porsche factory that went nuts with the spray adhesive.
If I were to do it again I would definitely go with the dry ice method over a heat gun and scraper. I think that would make it a slightly less arduous job.
I remember removing mine in the first 951 I owned... neighbors thought it was a biohazard. But the end result was worth it. Spec Racers commented on how clean it came out.
+100 on the mask. Your lungs will thank you.
