NA engine rebuild thread
Old 03-13-2016, 12:15 PM
  #61
Tiger03447
Tiger03447's Avatar
Looks good Michael..Seems that you are addicted to red paint..LOL!
Old 03-13-2016, 01:54 PM
  #62
odonnell
odonnell's Avatar
Default NA engine rebuild thread
Thanks!
Ran into a huge problem today.
There's a ton of 951 parts for sale a few hours away from a failed "can I turbo my NA?" project. It's almost too good of a deal to pass up... I may walk away from supercharging and build a turbo motor... Decisions, decisions...
Edit...someone snapped it all up already. Guess I'm supercharging it.
Old 03-21-2016, 09:51 AM
  #63
odonnell
odonnell's Avatar
Finally got the crank woodruff key off, after several weeks of having no luck. Turns out the using a center punch on it, from all the sides, does the trick when you couple it with PB blaster. That allowed the oil pump to come off the crank... this one has a 1981 casting date. It's cleaning up nicely (so much f'ing varnish) and the cogs are in good shape, so the source of the metal chunks in the oil pan is still at large. Maybe the head? This oil pump also has some residue, presumably from factory sealant, along the rounded edge that contacts the thick oil pan gasket. I thought they only used this stuff on the corners...it's a pain to get off.
Old 03-23-2016, 12:35 PM
  #64
odonnell
odonnell's Avatar
Question... can I re-use my NA wrist pins with 951 pistons, or are they dimensionally different? Looking to use the factory '82 Rarst rods with 951 pistons.
Old 03-23-2016, 09:03 PM
  #65
Ak951
Ak951's Avatar
I have 951 pistons and rods sitting around...I can mic the wrist pins if you need
Old 03-26-2016, 01:22 PM
  #66
odonnell
odonnell's Avatar
I may take you up on that I just need to receive those pistons. Paging lart...
Yesterday I got the ultrasonically cleaned parts back :
It's almost too clean to be true!!
Old 03-26-2016, 02:26 PM
  #67
JWebber
JWebber's Avatar
That is just amazing . I love clean parts to build with , guess I need to see if there is anyone fairly close to where I live that does this . All my past builds were just the old hot tank at the machine shop cleanings .
Old 03-27-2016, 12:29 AM
  #68
951Dreams
951Dreams's Avatar
Awesome, I want to find someone who does that too!
Old 03-27-2016, 12:31 PM
  #69
odonnell
odonnell's Avatar
Trick is to call around and look for a machine shop that offers a cleaning technique that's compatible with aluminum and importantly, alusil bores. The lot of places will hot tank or bead blast which can ruin bores. The ultrasonic cleaning I got was $40 for the block and $40 for the rest, which is very reasonable IMO.
Old 03-27-2016, 04:46 PM
  #70
JWebber
JWebber's Avatar
I went back and read through your build so far and it looks like you are wanting to use the same charger I picked up for my Corrado VR6 .
Old 03-27-2016, 08:48 PM
  #71
odonnell
odonnell's Avatar
Yessir! Where do you suggest looking for them? I've been combing junkyards, nada. I'm not happy with the prices people want on ebay.
Old 03-27-2016, 09:03 PM
  #72
V2Rocket
Rainman
V2Rocket's Avatar
i find them in the junkyards time to time, about $120 where I go.
ill keep an eye out...
Old 03-27-2016, 09:18 PM
  #73
JWebber
JWebber's Avatar
I picked this one up on ebay 3 or 4 years ago . it needed a front coupler , as most do . I have been trying to strip off the paint some genius sprayed it with along with the factory grey , that stuff is tough .
Old 03-27-2016, 09:23 PM
  #74
V2Rocket
Rainman
V2Rocket's Avatar
Michael, plug in 1991 Thunderbird into car-part.com...look for supercharger...there's a few listed for $100 or so.
Old 03-28-2016, 01:42 AM
  #75
951Dreams
951Dreams's Avatar
aircraft remover.... you can get it at wal-mart or most parts stores.
Quick Reply: NA engine rebuild thread
