Another 944 (S2) suspension question..
Hi everyone! Haven't made an official post yet about joining your ranks here on Rennlist yet but I've been a long time reader of this forum & am very happy to finally be part of the family!
So here's my problem. I've searched for my option code sticker in the trunk & it appears to have been removed by a previous owner at some point. It has option M220 (LSD), possibly the optional M030 *brakes* unless I'm terribly mistaken and I'm thinking something around the possibility of M474 suspension.. I've already tried looking around older Rennlist posts regarding M031 and M474 but can't seem to find anything quite relating to my specific setup. As you'll see I have 3 pink dots on my front springs/coils and Bilstein dampers out back. Does that mean I have something unique or that I'm just plain silly? The car is 110%, bone stock.
Seems like quite the complicated suspension option list!! Anyways, I know there's some extremely knowledgeable people on here and am hoping for a little help. It would be greatly appreciated. Planning on a phone call to the dealer here soon this week for an official build sheet.
Pardon the rust on the calipers, been cleaning all week!
Thanks,
Connor
https://drive.google.com/drive/folde...DhqX1FpS01BdUk
Thanks,
Connor
Connor, from your photos, it appears your car has standard, non-M030, brakes and standard, non-M474, struts/dampers.
Those front struts are probably OE Sachs/Boge, with stock springs. And the rear OE Sachs/Boge dampers were simply replaced with [nice] aftermarket Bilstein sports.
Looking good!
Looking good!
Looking good!
Looking good!
Guess I was overly optimistic. Was told it was all mechanically original by guy I bought it off of but must've been original owner from Japan before they sent it over. Not a big deal though. Appreciate the clarification!
Not to worry...you can easily replicate any of those options, with a few $$$, if you really wanted to.
Take a look at your brake calipers, front and rear. Look the same? That's because they are...same great, 4-piston, set up on all non-M030 951s and 968s. We call those "baby blacks".
The M030 option would have installed 928S4 calipers, AKA "medium blacks", in front only, and kept the same non-M030 caliper in the rear. M030 would've also equipped the 951/968 with Koni single-adjustable struts with threaded perches in front, and Koni single-adjustable dampers in back. For the 968, the M030 option put an additional barrel spring, with fixed perches, over the rear damper. M030 also replaced the standard 23.5 mm torsion bars with 25.5 mm bars for both the 951 and 968. Front sway went from 25.5 mm up to 26.8 mm for the 951 and up to 30 mm for the 968. Rear sway went from 18 mm down to 16 mm [yes, smaller] for the 951 and up to 19 mm for the 968.
The M474 sport damper option would have installed Koni single-adjustable, fixed perch, struts in front with Koni single-adjustable dampers in the rear. While similar to M030 dampers, these were valved for a little more compliance.
Thanks again for clearing up all of the info! Really appreciate it! Guess it's time for the mods to begin!
All in due time.
Drive the car a bit and let us know how she handles. Bilstein makes great dampers...depending when your rears were replaced, your back end should be firmly planted. Though, at this point, the front [OE?] Sachs/Boge struts have probably seen better days.
When you get a chance, post some photos of your new mistress.
All in due time.
I'll make sure to take more pictures here soon this week or at C&C this weekend. Just finished a paint correction and wheel restoration so pretty thrilled with the outcome.
Fresh pads and quality fluid will work wonders with the factory 4-pot brakes.
See if you can score a ride in a local 944 with fresh Koni sport struts. Jason [at Paragon] carries the inserts [~$400/pair] and they're essentially M474 spec. Transformational...
Any idea how old the rears are? They would be fine with the front Koni struts, but, when it's time, Jason also carries the rear Koni sport dampers [~$300], to match.
I'm going to be in the same situation shortly - Have a 1989 S2 no M030 -
From what I can gather - better to keep the TB and go with higher spring rates? I'd really like to firm up suspension considerably - maybe 3/4 of the way between a full street and full track - can't go crazy hard as I track at Sebring and you need some healthy travel and rebound.
Anybody have any recommended spring rates? I plan on going with full poly bronze - are stock sways enough? I plan on going with a 255 tire on all four corners - will rebuild brakes and new rotors - anything else? Don't mean to hijack - figure I am asking a similar - if not more detailed question.
400lb front/ 30mm rear TB's as a starting point?
My preference is heavier springs and lighter sways - but might not be quickest...
Talk with Carl Poetl at Racer's Edge - good source of info.
Cheers,
Mike
Cheers,
Mike
No worries! I'd actually prefer to get a few ideas on what direction people are taking with their cars chassis wise anyways. I'm looking for something that I'll be able to take to the track maybe 2 or 3 times per year but that stays primarily as a road car, so your stuff is actually totally relevant. My original question was more to do with identifying what was already there so I could figure out what I had to do to get it eventually to how I want it to be.
I would keep the torsion bars but increase them to 28mm-30mm range thicknees ones. At the front, I recommend 250-350 lbs range springs. I would keep the front sway bar for now but upgrade the rear to an adjustable OEM 19mm or thicker aftermarket one. This way there will be adjustability for finer tuning.
I carry some of these items in stock.
Feel free to contact me.
You can go with stock sways and stick TBs but will need helper springs at the back and ride height adjustability will be complex due to the TBs In place. You can go with much stiffer springs (600 lbs and up) all around but will need GOOD shocks, better than just the Koni yellows. I have tried more than 4 different brands and types of shocks on my car and finally decided to buy real racing shocks in order to run really heavy springs and get adequate dampening. The other option is to get custom valving done on one of the cheaper options Performance shocks.
So either step up and buy K&W or even pricier Vonns from Elephant Racing? Dang - those are almost as much as I bought the car for...
