951 reference sensor question
You can access them but expect grazed knuckles.
http://www.clarks-garage.com/shop-manual/ign-02.htm
Bookmark this page, you'll find much needed knowledge here.
They're sort of not bad to access. I left the intake on I think but I moved some of the wiring and tubing out of the way. If yours are permanently welded to the bracket and you need to replace them, heaven help you. This was the single most painful experience in my 951 life. A cold chisel to the ref sensor bracket was the final solution
I found it easier to pull the intake and tied some cables and lines back with tie wraps (zip ties) and then clamped a set of vise grips on the top of the sensor and sprayed some nut buster in there (don't know if it helped but it didn't hurt) and then twisted the vise gripes while pulling up. It took a fair amount of twisting but it eventually came out. Make sure you plug the viewing hole on the bell housing up with something so nothing falls in there.
