Solid Torque Tube?
I honestly can't find a split in mine, which is an '89 S2. I'm going down to the shop later this afternoon and will report back.
So it seems it was a change in manufacturing process rather than specification and the older tubes (more properly called a "central tube") can be transplanted into the newer cars.
I've also found a rebuilt ZF LSD for this car and an OEM transmission cooler so I plan to put in the new clutch, rebuilt torque tube & half axles, rebuilt transmission w/LSD, M030 sway bars (Lindsey Racing version) with poly race bushings from PowerFlex during this phase of the refresh.
I'm not putting coil overs in the rear yet, since I've never driven the car further that from the garage to the shop (maybe 100 feet), I want to get a feel for it before I really get into the suspension, but I figured the M030 bars were such a guaranteed safe bet I could do them now and the rubber bushings are completely shot so I had to do something to it before I could even drive it.
My goal is to build a tribute Firehawk car with this project. I probably won't go to extremes on weight savings, not planning to strip the undercarriage sound proofing for example, but I will delete the A/C, power windows, door locks, security system, radio, and the rear seats at the very least. Probably replace the power sunroof with a light weight removable carbon panel. Power headlight delete for certain. Maybe lexan all around on the windows. Lightweight seats.
You're welcome to come down and see the car if you feel like it BTW. It's up on the lift right now and the entire drive train is out of it, but it's still a pretty thing to look at I sent you my contact info in a PM the other day.
Thanks for the invite. I'm so busy these days I have to put #2s into my daily planner....
Maybe the newer version of torque tube started in 1990, like the hoop wing.
The split/slot is easy to see. It should have a strip of reflective metal tape covering it. It's on the bottom at the front (with respect to how it's oriented in the car), about a foot or two in length. I can take a pic of my 968 tube if it helps.
I've never heard of anyone having issues with using a 944/951 TT in an S2 or 968. My 968 currently has a 951 torque tube. I read somewhere on Rennlist that the slot was introduced to help reduce vibrations. I haven't noticed a difference.
I wonder why the tube can't be sealed up with a wrap of carbon fiber epoxy or a weld?
For the past six months I've been experiencing the joys of retirement. Now all I have to do is research and purchase Porsche parts, tear old parts out, put new parts in, and wait for the next track day. In the meantime I organize contractors to repair roof leaks and aging barn doors. On my off days I visit my doctor and shop for food ...
The guy who rebuilds TT on the east coast (He's in GA, but was in FL) and will only rebuild solid tubes as he says the center bearing can "walk" around in the split ones. Just sharing what I have heard.
It will be at least three weeks before I get my transmission work done so the TT isn't really the long pole, though it's funny the way things you think are going to be easy suddenly turn and bite you on the butt during projects like this This will be my first experience with the 944. I've restored a 914, a 924 and a 928, never touched a 944 before this. The car is in great condition, I bought it last year from a fellow in Sarasota, it appears to have been a garage queen. It's almost too nice to turn into a track car.
So you have #51? I'm planning a Firehawk tribute with this build so any information you have on hand about the original specs for that car would be very much appreciated, especially books or original factory parts lists? Thanks for joining the conversation!
I've already ordered a Lindsey Racing M030 front/rear sway bar package and sourced a ZF LSD through Dimi along with an OEM transmission cooler. I know there are more contemporary LSDs available for the car, but I honestly would like to know what the '91 Firehawk cars felt like to drive before I do anything radical to it. I haven't got the entire suspension planned yet, but I needed to replace all the rotted rubber bushings before I can even drive it to the supermarket so I decided to do the M030 upgrade more or less blind.
I remember reading somewhere (I think from someone very knowledgeable here on Rennlist) that welding is the way to go... it's not straightforward, there are couple reinforcements that must be added. IMHO easier to find a solid TT from a parts car.
So, where do I sign up for this project...
Rogue.......rarely
Profiteer......ha!
I have given away so many parts to fellow racers and rennlisters to keep these cars alive, hardly, I'm not even a "breakeveneer"
Let's see where he's locating first, might not be logical yet.
