'88 N/A motor in a early '85
Hi guys, found a low milage 88 motor and would like to see what would it take to adapt to my early 944. I think most of the sensors would have to stay from the 85 motor to work with my dme? Or would I need to carry over the 88 dme, AFM and harness? I would like to just swap the long block or would I not see the full potential of that particular(higher compression) engine with the early DME program.
If it matters, this is a dedicated track car and emissions are of no consequence.
Thank you, Kevin
Thank you, Kevin
The early harness will work but you won't be able to use the oil level sensor in the oil pan definitely use the 88 dme and afm to get the slight cam advantage and higher compression pistons.
You should keep the '88 injectors with the '88 DME - they are a different impedance than the early injectors.
But definitely use the early harness - the '88 harness goes through the firewall at a different spot and will have the wrong plug for the instrument/power harness (connection by the brake booster).
The exhaust manifolds on your 85 might be cast iron. On the '88 they would be tubular steel. The tubies weigh like 20 pounds less, but they often crack and leak. If it's a race car, then use the tubies!
