Rotor centering rings
Anyone still make them? need them for the 350mm cayenne rotors
I want to put the final touches on my brake swap, and kill that little bit of vibration I have left.
I asked Xschop a while ago, he wasnt making them separately. I had a pair made by these guys http://9xx-parts.com/, fit perfect.
I will make you a spare set this weekend. Paypal $80 to rmott@ouhsc.edu
Ill get them in a priority box.
Only doing so because I am designing another kit with the cayenne rotors, so Ill be on the lathe.
996T adapters and Cayenne 330 rotors on 951 spindles hubs to be exact.....PM if interested Ill make extra of those as well...
A few 928 LS swaps and a v12 swap got a set of these...
BTW the 330 and 350 cayenne rotors both have the 85mm hub I.D. dimension so the centering rings are the same and can swap out. Don't forget to add the 0.0625" chamfer if you want your hubs to last.
https://rennlist.com/forums/928-foru...otor-swap.html
