Convert ABS signal to speedo signal 968
Old 12-29-2010, 05:00 PM
924turbo2
924turbo2's Avatar
Default Convert ABS signal to speedo signal 968
I am using 968 hubs/brakes on my 931. I lost my old cable drive speedo hubs with the conversion.
Problem is I want a speedo signal. I know the 968 unit takes the signal from the ABS.
I am not using the 968 abs system.
My question, will the relay 96461822000 be enough to convert the abs signal to a speedo signal or do I really need the ABS control unit also ?
Old 12-29-2010, 08:14 PM
JimV8
JimV8's Avatar
I think you'll need the ABS unit.
Old 12-30-2010, 10:53 AM
924turbo2
924turbo2's Avatar
I don't want to think it, I want to be sure
The relay is called: ''control unit frequency converter'' so I assume it converts the ABS signal to speedo pulse.
The ABS control unit just uses the ABS sensor pulse for the antilock brake system.
Quick Reply: Convert ABS signal to speedo signal 968
