Battery won't stay charged
I bought a new battery, Duralast, earlier this year. It keeps going dead. I hooked it up to a charger, and it charges up fine. I started it as late as last Monday or Tuesday. I go out to start it today and it's dead again. It's a new battery, It only sat there for less than a week, what's wrong? Could the battery be bad?
Get a volt/ohm meter and meter what you're drawing with the car off. Start pulling fuses until you find the culprit, then track it down. Just about all of us here have had to do it (probably).
I'm sure many can help...you just need to start narrowing it down.
No really strange - not on these cars. You have a parasitic battery drain.
All batteries are not created equal! I thought my old (at least 5 year) battery
was getting tired so I traded it for a new Napa.I was better off before.at least the old one would hold a charge. I wish I had saved my warranty/receipt on this one!
In my case, it was the door switch; cleaned it up and all was well. You can eliminate this by checking window operation,
edit: couldn't find the post. Here's one I found that i posted earlier
basically, the door switch is stuck "in" - symptoms would be:
- your overhead lights won't turn on, and
- right after you shut the engine off, your windows have power for a bit until you open the door - if, right after you turn your engine off, you can open the door and your window operates, it's the door swtich
+1 on the parasitc drain
I'll be keeping an eye on it still but this is a step in the right direction.
Thanks again.
I had the same problem. It ended up being a glove box door that did not shut completely, so the glove box light slowly drained the battery.
I almost changed my alternator over this issue, because some car electric 'expert' shop told me the alternator voltage was low under full accessory load. It was BS!
