engine degreasing
Old 11-07-2007, 01:59 AM
paluck
paluck's Avatar
Default engine degreasing
Hi,
I'm looking for recommendations on where I can get my engine degreased. Bay Area - norcal. I've called some car wash places and they don't do it. Self-serve places expressly disallow it and I'd liek to be environmentally responsible if I can.
A shop said they'd do it for $150 - but that sounds a little much for some spray degreaser and a garden hose.
Any advice?
-M
Old 11-07-2007, 02:03 AM
nh7cy
nh7cy's Avatar
First off, welcome to Rennlist, secondly, why not do it yourself? Go to the Autozone in Oakland, pick up some degreaser, spray down your engine and hose it off.
Old 11-07-2007, 02:12 AM
paluck
paluck's Avatar
Hi Jason - thanks
i would do it myself, but
1) I haven't cleaned my engine in.... well... the last 9 years I've had the car - so its a little icky and I didn't want to crap up my light colored concrete driveway with the sludge
2) I'd prefer to do it somewhere they can properly dispose of the 9 years of crud properly.
Old 11-07-2007, 08:39 AM
Josh B
Josh B's Avatar
$150 sounds like a good deal to me especially if they have the ability to clean off the bottom of the engine as well. Being environmentally conscience isn't cheap
Old 11-07-2007, 09:52 AM
Stephenwz968
Stephenwz968's Avatar
This may sound ghetto, but the way that I do it if the engine is really dirty is to drive the car on top of an old quilt, and then degrease and hose down. The quilt collects the water and sludge, and is thrown out after the process is complete. Just an idea...
Steve
Old 11-07-2007, 10:02 AM
Luis de Prat
Luis de Prat's Avatar
How about just driving it to a DIY car-wash facility, spraying down with degreaser and rinsing it out? These facilities are prepared to handle grease sludge in their sewage.
Old 11-07-2007, 10:05 AM
Spidey944
Spidey944's Avatar
Keep in mind you do not want to have your engine steam cleaned. The moisture get into all the elect. connectors and after 20 years of wear, the insulation on the wires is not what it used to be and corrosion can get into the wiring and mess it up. Just a for-warning.
Old 11-07-2007, 10:50 AM
paluck
paluck's Avatar
hmm.... I actually like that old quilt idea - that sounds pretty good - maybe thats the way to go.
Old 11-07-2007, 02:46 PM
Da Bears
Da Bears's Avatar
I'm glad this thread came up because I have been thinking about this and I've got a question or two for those of you who have done this.
Many moons ago, I used to clean every so often the engine of the first car I ever bought new. I did it in the fashion described by you guys - spray with degreaser and then garden hose off. Problems arose that I like to attribute to that process. Some electrical issues, but the most annoying thing of all was that one or some of the belts squeaked ever since I did that. It drove me nuts.
Ever since then, I basically make no attempt to clean any of my engines. Modern engines stay pretty good looking due to all the plastic coverings, etc. hiding everything (like the L6 in my Denali).
So, question here - to those of you who have done the simple spray-degreaser-garden-hose thing, did it leave the "sound" of your engine (especially at cold start-up) the same? Any other problems creep up? Any other ideas of how to clean the engine without doing an unnatural thing like dumping water all over your fine piece of German engineering?
Thanks for the thoughtful replies to come.
Old 11-07-2007, 02:56 PM
reno808
reno808's Avatar
after your done just power wash your drive way. You will be fine.
Old 11-07-2007, 03:04 PM
PorscheDoc
PorscheDoc's Avatar
A case of Brake cleaner, a big catch pan and a toothbrush for the extra stubborn areas.
Old 11-07-2007, 04:04 PM
alordofchaos
alordofchaos's Avatar
You can throw a plastic bag over your fusebox, distributor, belts, and other parts you don't want to get wet.
Old 11-27-2007, 03:25 AM
IPSC
IPSC's Avatar
See that is my method. Glad to hear I am not totally off base.
IPSC
Old 11-27-2007, 06:05 AM
Jay W
Jay W's Avatar
I put cardboard on the driveway under the engine, sprayed just enough degreaser to loosen up a small area of dirt, then wiped as much as I could with rags. Then repeated. What I didnt get on the rags dripped onto the cardboard. When I got most of the dirt off, I then removed the cardboard and rinsed with water. Threw away the rags and cardboard. Barely got any degreaser or dirt on the driveway that way.
Old 11-27-2007, 09:27 AM
sbyrne
sbyrne's Avatar
You can help to avoid electrical issues by using your garden hose gently, and at close range, along with the plastic bag advice stated aboove. Standing back and blasting away (especially with a car wash wand or a pressure washer) is asking for trouble.
Quick Reply: engine degreasing
