Weight of carpet and sound deadening?
Old 10-01-2006, 03:12 PM
theedge
theedge's Avatar
Default Weight of carpet and sound deadening?
Ive been searching but I cant find an actual number. Does anyone know what all the carpet and sound deadening from a late interior weighs?
Old 10-01-2006, 03:16 PM
tinman944
tinman944's Avatar
A lot!!!!!Sorry I had to say it.
Old 10-01-2006, 06:04 PM
schwank
Herr Unmöglich
schwank's Avatar
I did not weight it exactly, but I'm going to guess around 15-20 lbs. The rear hatch carpet alone is probably 25% of that with its' integrated padding. This is out of my 87 NA.
The last half pound was the hardest though... stupid tar paper on the tunnel.
Old 10-01-2006, 07:24 PM
smlporsche
smlporsche's Avatar
Well you asked for it. Here is my (almost) complete list of everything I removed and the actual weight in my S2. Enjoy!
Reductions / Additions Completed
Remove L & R Rear side carpets w/ shoulder belts & Rear Cargo carpet -21
Remove Rear Upper Seat back rest -24
Remove Spare Tire & Tools -38
Remove rear wiper motor & wiper -3
Remove center console, radio bracket & door speakers -8
Remove sunroof motor & gears -6
Remove side roof padding between A & C pillars -2
remove rear seat side trim -4
Remove front floor carpet & insulation -15
remove rear lower seat -5
Switch to FG sunroof -3
Remove cruise control module & wiring -3
Switch to racing seats (Car weighed 2740 w/ 3/4 tank, not 2768 est.) -50
Remove additional sprayed in insulation -14
Replace aluminum lugs w/ steel 2
Install rear tow hooks 2
Remove door glass and motors -28
Add roll cage 100
Delete headlights & motor -20
Replace exhaust system -17
Old 10-02-2006, 09:55 AM
tinman944
tinman944's Avatar
smlporsche 2688#
I put everything that I have taken out of my car on the scales, I wish I kept track of it as you did.
I would just mark the part and throw in in a pile.
Old 10-02-2006, 07:08 PM
theedge
theedge's Avatar
Thats for that list Eddie!
Old 10-02-2006, 07:14 PM
smlporsche
smlporsche's Avatar
I'm glad somebody gets to enjoy the fruits of my labor !!
Old 10-02-2006, 08:49 PM
FRporscheman
FRporscheman's Avatar
All I've done is to delete the rear wiper... a measly 3lbs... Thanks for the list!
Old 10-02-2006, 11:10 PM
Netrunner09
Netrunner09's Avatar
I actually just finished redying my carpet and in the process took out all the sound material. Total weight in a cardboard box of rear hatch sound mat (heavy), side panel mats, driver and passenger sound mats (also heavy) and all the other pieces I could get off relating to sound muffling totaled 52lbs. Again, just the sound material, not carpet or other stuff. hope this helps you
Joe
edit:this was from the 86 Turbo
Old 10-02-2006, 11:16 PM
Rock
Lazer Beam Shooter
Rock's Avatar
The sound deadning is pretty heavy.
The carpet is not however. The sound deadening was removed in my old yellow car, so I just bought a carpet set and put it down.
The carpet cant weigh much more than like ~10lbs. Removing the carpet for that small of a weight reduction isnt a good idea if you drive your car for street/DD use IMHO.
The 924SE with like manual windows, 1 mirror, and stuff still had carpet. Supposivly those cars were made for track use, and they still had carpet. Really funky carpet at that.
Old 10-03-2006, 12:19 AM
J Silverman
J Silverman's Avatar
Actually the carpet is just maroon. The door cards and seats are butt ugly gray with maroon stripes. They do have just as much carpet and sound insualtion as the other 924/944s Ive seen. I took mine out to prep for this:
If you look on the passenger side you can see the ugliness that the interior was blessed with. The factory claimed 2618 for the car, I wonder how much it weighs now!
Old 10-04-2006, 03:42 AM
derSchatten
4th Gear
derSchatten's Avatar
Question
How much did the Lower part of the back seats weight?
I know that alot of you Race on the track.
I'm really looking for a "nice" looking car with a sweet sound system and enough performance. Minimal Road and Engine Noise.
(replace old worn carpet and aged noise dampening)
I'd like to strip the carpet and the old sound deadening.
(a Little weight gained back but killing lots of noise)
I'd like to use some of the Spray On Sound Damper.
(a little more weight gained but really quiet now and more insulated)
Perhaps look for some of those Dynamat alternatives.
I recall seeing a few that were more heat resistant and made of rubber and Vinyl, and apparently veary lightweight.
(add More weight but gain a Sweet system)
Replace the backseats with a compact dual/or singal subwoofer box. Maybe some 10" MB Quart or Nakamichis.
(loose Lots of weight but not sure about safety)
Replace the hatch window with Lexan, and maybe the front window too.
Hood should be Carbon Fiber but look like stock.
Does anyone have any pictures of the rear seat delete with Subwoofer Box replacement?
I'd like mine to look veary stealth and appear like i just have my rear seat folded down.
Old 10-05-2006, 02:48 AM
derSchatten
4th Gear
Default BUMP
Newbie here, just bumping the thread.
Hope someone will answer my question.
Been Wondering about this Mod for years.
I Should really concerned about getting my Slave Cylinder Fixed and taking care of the Eletrical Grimlin that kills all of my batteries in a matter of minutes.
Can Anyone help me?
Quick Reply: Weight of carpet and sound deadening?
