Parking Brake Removal
Looking for directions on how to remove parking brake. Also need to know if it will be necessary to adjust it when I put it back on.
I don't know what parts you're talking about. The lever next to the driver's seat or part of the mechanism at the rear wheels? The haynes manual has a pretty good description.
Dan, fill us in on the details. I know the rear calipers have to come off, and in my case the 17mm bolts were on rock hard so I just replaced the pads and put it off for later. How did you do it? Cheater bar?
1 Post
The parking brake uses the inside drum portion of the rear brake rotor hats. Unless someone drove around with it engaged you shouldn't have to change the shoes, and a thorough cleaning with spray brake cleaner should help operation. I think the only place to adjust them is at the handle, but it's covered in Haynes.
SoCal, I beg to differ. Although I've thoroughly read the procedure in Haynes and Clark's Garage, I still find that it's always valuable and encouraging to hear first hand repair information from other novices on this forum like myself.
SoCal, I removed mine because there is an o-ring behind it that seals it to the trailing arm and keeps water from seeping into the bearing cavity. I replaced the o-ring and added some silicone for good measure.
