924 coolant expansion tank alternative?
Hi so my tank decided to crack and start squirting coolant last night and i put some jb weld as a temp fix so i could make it home. Now i did a search and it turns out these tanks are prone to cracking at the dimple, which is where mine cracked. I looked for a replacement and have not found any. But I see a lot of 944 tanks available, can I use one of those? Or is there another easy to find car that I could possibly pull the tank from?
Rainman
According to ideola you can't fit a 944 tank to an NA 924.
http://garage.ideola.com/prod-CoolingSystemKits.html
But it's just a coolant tank - you can use anything from any car as long as the hoses hook up and you can mount it to the car somehow.
What about 951 coolant tank alternative?
R
It's angled down and has a 35 degree metal pipe in the middle before more hose to the rad.
All done to keep it out the way and area where the Inlet I had hoped would come in straight from the vented badge panel and straight into the TB and then modified neck Inlet manifold.
The original plan was to go with a Programmable ECU / AFM Delete / MAP system / Wasted spark etc.. from a UK company who were going to install it all and map it!
But this relationship got ugly, so I got out asap and went to a proper Engine tuner, builder and Mapper instead as you know they insisted on me using all the stock Bosch ECU / Fueling and Ignition.
R
