924 and 931 Forum 1976-1988
Refinished my Phone dial rims
Old 07-27-2015, 03:12 AM
michaelo
michaelo's Avatar
Default Refinished my Phone dial rims
Just repainted my phone dials and I am very happy with the results. I used Dupli-color Hyper Silver spray paint kit.
Total cost= $20 + my labor.
Old 07-28-2015, 02:01 AM
mel_t_vin
mel_t_vin's Avatar
That turned out well...nice job.
Old 07-28-2015, 02:17 PM
michaelo
michaelo's Avatar
Thanks! Each wheel took about 30 minutes. Well worth it.
Old 07-30-2015, 01:53 AM
mel_t_vin
mel_t_vin's Avatar
Did you go through several iterations of paper...e.g. 200, 500, then 1000 grit?
How many coats of color did you put down? Hard to tell...then top off with 1 or 2 coats of clear?
Old 08-03-2015, 01:56 AM
michaelo
michaelo's Avatar
I didn't use any paper at all. Here is exactly what I did:
1. Jack car up and remove wheel
2. Cleaned wheel front and back 3x with a good de-greaser, a brush and a garden hose. Remove wheel weights and glue using some wd-40 and Brillo pad.
3. Dried it off with my leaf blower
4. Removed all the air from the tire so I can push the tire in slightly around the rim and place some cards around it [to mask it off] [see pic] I also taped off the center cap Porsche crest.
5. Gave the rim 4 light even coats of Dupli-color hyper silver paint
6.Wait 30 minutes
7. Gave the rim 4 light even coats of Dupli-color clear
8. Refill with air using my Viair pump [I highly recommend you buy this air pump-its the best]
Amazon.com: VIAIR 85P Portable Air Compressor: Automotive Amazon.com: VIAIR 85P Portable Air Compressor: Automotive
That's it. No sanding, no buffing - nada.
I already put about 100 miles on them and washed them once and so far they have held up just fine. Here is a pic from today - they are a little dirty but easy to clean up with soap and water.
Old 09-27-2016, 09:07 PM
dclax
dclax's Avatar
Does the center cap come out easily? I think I might do what you did because mine are badly faded. Looks really good!
Old 09-27-2016, 09:32 PM
FrenchToast
FrenchToast's Avatar
When you do it you should mask off the lug seat area. These are unpainted from the factory (in order to maximize friction).
Quick Reply: Refinished my Phone dial rims
