924 and 931 Forum 1976-1988
AC blow warm - should I convert to R134?
Old 03-13-2015, 02:26 PM
michaelo
michaelo's Avatar
Default AC blow warm - should I convert to R134?
My car is a 1988 924 S and the summer is coming and i would love some cold a/c. Has anybody done this conversion successfully? Any tips would be greatly appreciated.
Old 03-13-2015, 04:19 PM
griffiths
griffiths's Avatar
Easy job. I did to my 78, 84s and 89s4 sharks
R134a Conversion
Old 03-15-2015, 08:23 PM
John_AZ
Proprietoristicly Refined
John_AZ's Avatar
Comment on the "easy job".
I converted my '87 924S to R134a in 2009.
I bought a professional rebuilt compressor, new receiver dryer, and seal kit.
I flushed all the lines and the condenser (old oil and dirt collects at the bottom of the condenser-reverse flush).
Bought a Harbor Freight electric Vacuum Pump.
Vacuumed for about 90+ minutes and vacuum held.
Installed 24 OZ of R134a and proper oil. (Sams Club sells a R134a case of 12 in PHX for $50 + tax).
A few weeks later the AC was empty. Removal of entire blower/AC housing under dash was required. Located the leak in the evaporator coils-replaced evaporator. Resealed every O ring in the under dash blower, evaporator, expansion valve and hose. Vacuumed and refilled with R134a.
As Griffiths mentioned it is an "easy job" if you have some skills or a pocket of cash for the shop.
You will not get the same cooling you had with R12. R134a works in Phoenix because it is a "dry heat". In areas of high humidity, to get the best cooling with R134a get an improved high performance condenser.
Griffiths sells one.
http://griffiths.com/porsche/air-con...ac-condensers/
AC with R134a has worked fine for over 5 years in the '87.
GL
J_AZ
Old 03-17-2015, 11:38 AM
michaelo
michaelo's Avatar
Thank you for the excellent information ↑
Old 03-24-2015, 03:59 PM
V2Rocket
Rainman
V2Rocket's Avatar
i too did the "full conversion" including evaporator removal/flushings, all o-rings, new drier, and a spiffy aftermarket condenser.
the AC works very well until it gets into the high 90s-100s outside. there it still keeps you cooler but it does not get "cold".
the early 944/924 cars have poor airflow from the vents - if you have a passenger splitting the ac you wont be as comfortable as having both center vents aimed at you obviously, but it is passable.
its better than not having it.
the 944 needs more fan power and probably a larger evaporator/condenser pair to have better ac...i might have an idea in mind.
Old 06-29-2015, 04:24 AM
michaelo
michaelo's Avatar
I got my hands on a can of R12 - refilled it and its ice cold now. Total cost $20 bucks.
Glad I did not convert it.
Old 06-30-2015, 01:55 PM
V2Rocket
Rainman
V2Rocket's Avatar
where the hell did you get R12 for $20?
in CA you can't get a can of R134 for $20.
Old 06-30-2015, 02:44 PM
John_AZ
John_AZ's Avatar
Probably the same place I search...
http://sacramento.craigslist.org/pts/5082800978.html
J_AZ
Old 06-30-2015, 05:36 PM
AUaviator
AUaviator's Avatar
Well then, I might just get a can of R12 from that CL ad and call it a day! Hopefully he still has some.
Old 06-30-2015, 07:35 PM
V2Rocket
Rainman
V2Rocket's Avatar
****, you guys better scoop that up ASAP.
ive been on R134 for years so its no good to me.
Old 06-30-2015, 07:42 PM
John_AZ
John_AZ's Avatar
Some legitimate sellers want to see your EPA certificate or sign a waiver. I took the test and passed for my basic certificate.
http://www.epatest.com/
Info from:
http://the944.com/ac/default.htm
Pick up a R-12 2 OZ oil recharge can if you find it.
J_AZ
Quick Reply: AC blow warm - should I convert to R134?
