914/4 distributor rotor - performance version???
2nd Gear
Hello,
I'm posting here as a bit of an interloper. I haven't got a Porsche but I am looking for Porsche part information for my '68 Saab Sonett.
I've been told that the 914/4 1700 distributor rotor is a drop in replacement in the Bosch distributor in my Sonett and would provide an easy solution for a rev limiter. (I bent a rocker shaft a couple autocrosses ago and am looking to curb my revvy foot a little.)
However, the rotor I've found available is part number 022-905-225A and provides a rev limit of 5800rpm. That is a bit too low for my needs. I'm looking for something more like 6500rpm.
So... I was wondering if there was a performance version of this distributor rotor available? I haven't been able to find one yet.
-STEFAN
ps. In case you were wondering what my Sonett looks like, this is a good pic from an autocross earlier this season. http://www.goof.com/~mmead/blacksbur...s/DSCN3285.htm
-STEFAN
Hello
Those fingers where widly used on european cars. Bosch covered a wide range and I think the pre 1971 Porsche 911 have the same finger with various rev limits up to 7500/min.
around 6500 was the 914/4 2,0 limit.
To order that part you just need the base Bosch number on the finger ( normaly ending with 3332 ) and the last number is the rev limit. Mostly it is in a small circle or some kind off stamped on.
I know how sonetts look and drive. Steve Stromberg also has one. he is around att pelicanforum or shoptalkforum.
The sonett V4 is a european Ford Taunus engine. Some british tuners still cover high proteine parts.
Grüsse
Grüsse
2nd Gear
Roland,
Thanks!
That is great [detailed] information!
I'm off to find my new rev-limiting distributor rotor!
-STEFAN ...just completed another weekend of autoxing without breaking anything
Thanks!
