66 Porsche 912 restoration project from Pakistan
#61
Further advances. Having driven it now for a couple of years..not a lot ..depending on weather etc....its been on several long trips to our hilly areas..its been to teh Afghan border...Torkham border post and Michni down the Khyber pass as well as been shown in our classic car meets in Islamabad...these are all 300 miles away...I decided that the original 1600 with the Kardons didnt do the car justice.
Ordered a 2275 stroker with a scat C35 cam and twin 44 carbs..a daily driver set up with torque which will hopefully later allow me to set up an air conditioning system as well to make it a total daily driver.
#62
So nice Keep the thread going with the new motor install.... please!
#63
Cruisin'
Wow! Just wow!
It’s great that people like you with the Porsche passion are willing to carry out this “craziness” in places where it’s perhaps considered an eccentricity. Sure, the nuttiness of keeping these cars alive is eccentric to a degree, but you’ve shown dedication to the faith. This is to be saluted.
Keep us all apprised of your continuing progress.
Superdave312 (08-14-2020)
#64
eccentricity
Wow! Just wow!
#65
the 2276 stroker
the stroker engine finally arrived from the USA. Ordered form Summit racing who get SCAT to subcontract for them ...or does SCAT get Summit racing to market for them??? The engine is going to have a pertronix distributor and coil.
#66
The tin has been put on...doghouse cooling tin... and the IDF 44s are on. There is one problem though...attaching an oil cooler.. but the oil pump cover is fouling the crank pulley. I think the solution will have to be a spacer with machining of the pulley. A 5 inch pulley is supposed to do the job as well but it slows the fan down defeating part of the purpose of the oil cooler so illogical.....Thank goodness the exhaust has fit well....the 2276 is the same width as a standard 1600 engine
#67
new exhaust for the stroker
The engine in position. There have been several developments. Attached an external oil filter and oil cooler. This turned out to be a disaster as there were several leaks...the pipes would slip and the oil sprayed out during driving twice. I decided to dispose of the external oil system. The Vintage speed exhaust a 356/912 for the type 1 stroker custom made for the car was obtained from Vintage speed in Taiwan.
ALRandall (01-15-2021)
jbkanas (08-12-2022)
