911 Forum 1964-1989
Porsche 3.2
Old 03-22-2015, 03:22 PM
  #31
theiceman
Team Owner
theiceman's Avatar
Received 1,026 Likes on 730 Posts
Okay maybe it's just me but I have no idea what a pushrods tube is
The most common sources of oil leaks are many. It is not world ending as a lot if cars leak oil.
Oil return tubes
Triangle of death (oil sender, internal thermostat, breather cover )
Oil cooler seals
Valve covers
To a lesser degree:
Rocket shafts
BAse gaskets
Chain box -cam tower interface
Rms
Cam tower - head interface
Old 03-22-2015, 03:59 PM
  #32
gerry100
gerry100's Avatar
lots of proven good advice here.
When everything seems to be working and fluids are up to snuff a good " German tuneup" is on order
Old 03-22-2015, 06:13 PM
  #33
HorstP
HorstP's Avatar
pushrod tubes exist on air cooled aircraft engines, but certainly not on ours...
Old 03-22-2015, 07:49 PM
  #34
Joes911
Joes911's Avatar
Sorry, old habit on the pushrods tubes. Yes, they are oil return tubes. Ps, Corvairs were not Overhead Cam and the oil returned thru the same tubes the pushrods ran thru.
Back to orig poster, flush your brake fluid soon. Possibly the most over looked on cars not tracked regularly. Js
Old 03-23-2015, 06:19 AM
  #35
Pc007
Pc007's Avatar
Thanks a lot guys!! Will have all that into consideration when addressing these problems. I wish I was in the USA, here I dint have so many skilled mechanics to deal with these
Problems...here we go!
Old 03-23-2015, 10:56 AM
  #36
theiceman
Team Owner
theiceman's Avatar
just take it apart yourself
lots of good resources for this if you are mechanically inclined
Mine is completely to pieces and i have found nothing overwhelming yet.
Old 03-23-2015, 11:42 AM
  #37
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Talking
Taking it apart is easy... even I can do that
Old 03-23-2015, 11:51 AM
  #38
GTgears
GTgears's Avatar
356,912 and 914 all have pushrods, not just airplane engines.
Old 03-23-2015, 06:38 PM
  #39
Pc007
Pc007's Avatar
Hehehe taking it apart is easy...the difficulty would be to put it back together... I would end up with a 5 cylinder car, and some parts to do an ashtray!!! Hehehe
It would be fantastic if I had someone to help me do it and guide me...but the "do it yourself culture" is not as wide here as it is in The USA...unfortunately.
It's even hard to find a good honest Porsche specialist mechanic...there's always someone trying to rip you off.
I just recently changed the oil on my 964 and it was a very satisfying moment...a sensation of achievement...
Old 03-23-2015, 06:56 PM
  #40
Wachuko
Wachuko's Avatar
Question
......but the "do it yourself culture" is not as wide here as it is in The USA...unfortunately.
Where is home?
Old 03-23-2015, 09:55 PM
  #41
Pc007
Pc007's Avatar
Europe...between Portugal and Spain.
Old 03-25-2015, 07:31 PM
  #42
Pc007
Pc007's Avatar
Hi guys...have the car doing a service, oil, plugs, valve covers, brakes pads, etc.
I've seen I'll have to invest in the near future in:
- exhaust system...should I go stock? Or "improve" sound, (without going bankrupt please). I have a G pipe on my 964 and love it...100 dollars "upgrade...
- clutch, should I go stock or reinforced? Will the car handle differently?
Would appreciate your opinions...
Old 03-26-2015, 03:09 PM
  #43
Wachuko
Wachuko's Avatar
I also have a 964 and regret moving to the Fabspeed system... the sound of just the cat delete and G-Pipe was awesome... anyway, back to the SC...
You say, without breaking the bank... that does not give too many options
I am doing this to mine, but you are looking at close to US$3K:
With these to quiet it down a bit...
Old 03-26-2015, 05:58 PM
  #44
Pc007
Pc007's Avatar
Wow...if that sounds as it looks, it should be amazing.
Yeah, the 964 G piped sounds like a 3000 Dls system...for 200 dls....
I'm looking for a 1 single outlet system...should I go OEM or the spaghetti racing system? Anywhere I can hear sound differences? In The YouTube videos the sound improvement doesn't seems much...
That car looks fantastic, is it a 3.2 with a conversion?
Old 03-26-2015, 06:03 PM
  #45
Wachuko
Wachuko's Avatar
If you are just looking for sound... get a M&K muffler. That is what you see there. It comes in different configurations.
Quick Reply: Porsche 3.2
