Swepco 201
I am not sure where you might find it already in Toronto, but I do know that you can order this via ebay and have it sent to you.
Obviously not what you were initially asking for, but a solution just the same.
Erik
Erik
Team Owner
I live in Cambridge and get mine from guelph
I am sure if you go to the Canada regional forum someone will know as there is a huge Toronto Rennlist contingent
Parts Specialist
order some Kendall NSMP from Pelican and be done with the oil search
http://www.pelicanparts.com/cgi-bin/...281%20Quart%29
I'll second that comment! 80w/90 if the OP's trans is a 915 or earlier model, BUT 75w/90 Synthetic Kendall GL-5 for G 50 or later transmissions!
I wonder if the GM stinky stuff is just re-bottled Kendall LSD additive (the stuff that requires TWO latex gloves on each hand to put into the trans)!
