oil overfill and white smoke
Team Owner
Okay I know your new so don't take this the wrong way but stop F'ing aroud with this car ... Oil pressure has noting to do with oil level , that is indicative of the pump , bearings oil temp , etc.
1. get a big pan , drain all the oil and start over ... consider the cost of oil the price of your first leson
2. Park the car until you get either a manual or some help from an experienced owner.
You don't say where you are .. why not post a pic tell us a bit about you and maybe a lister lives close by that could go over some basics with you .
Good luck
Good luck
Parts Specialist
I am really scared!!!
added 5 quarts!!!
you realize the oil is checked WITH THE MOTOR RUNNING.... I would never let mine get down that low...if its 5 (or 4) over dont start it!! i would not....you need to have a new base line in this case. Remove all oil (if you lman to re-use make sure its in a clean bucket)
drain both plugs and fill with 10 quarts
drive till warm and SLOWLY fill to the line (I normally run about midway between the two or just at the point where my level guage is bouncing at idle)
added 5 quarts!!!
Parts Specialist
I have no info as to the 993's and how to change/check oil.. I know they are differant, something about removing an access cover on the side by the passenger rear wheel....???? I really am NO HELP for you on that car
you can as on 993 board or a couple people here know those as well
