911 Forum 1964-1989
1971 Porsche 911e engine info
Old 11-23-2005, 11:02 AM
Lex Luther
Lex Luther's Avatar
Default 1971 Porsche 911e engine info
I recently purchased a '71 911e, it was told to me as having the 2.4 engine, all my research, with the exception of a few cars for '71 show the 2.2. How can I go about finding out which engine I have, and is the much difference?
Old 11-23-2005, 12:10 PM
Peter Zimmermann
Peter Zimmermann's Avatar
1971 engines were 2.2 liters displacement. Look at the engine to the right of your alternator belt and you will find the engine number stamped on a vertical surface facing to the right. It will be 7 digits that start with "611", followed by 4 digits which are consecutive serial numbers. Just past (forward) of that number, on a horizontal surface, you will find a second number which is the factory internal designation code. That number will be three digits, such as "911", followed by a forward slash and two more digits, such as "01." If you got a 2.2 911E engine that number will read 911/01. Depending on grime level you might have to use an aerosol cleaner to see the numbers clearly. Congrats on your find, I hope that you got a good one!
Pete
Old 11-23-2005, 12:31 PM
Lex Luther
Lex Luther's Avatar
Thanks! The number to the right of the belt, on a vertical surface, it 7 digits, but doesnt start with a 911...its 6210398.. followed by a little star stamp. I havent found the other numers yet.
Old 11-23-2005, 05:40 PM
Peter Zimmermann
If your number starts with "621" that means:
6 = 6 cyl.
2 = 911E
1 = 1971
0398 = serial number
Congrats, you have the correct engine...
Pete
Old 07-11-2014, 01:28 AM
niche
niche's Avatar
Reviving old thread to see if anyone knows what engine this number is from:
6107752
Old 07-11-2014, 01:34 AM
Cuda911
Cuda911's Avatar
I did some research. This is all I could find:
Old 07-11-2014, 04:05 AM
niche
niche's Avatar
Mike, so useless, my friend. Go back to taking pictures of your 914.
Old 07-12-2014, 02:42 AM
Cuda911
Cuda911's Avatar
No need for thanks, carry on.
Old 07-28-2014, 06:21 PM
derekw
3rd Gear
derekw's Avatar
6 cyl
1=T
0= 1970
Old 08-02-2014, 11:38 PM
niche
niche's Avatar
Thank you! So wrong engine date. Good to know.
Quick Reply: 1971 Porsche 911e engine info
