Wheel and Tire Forum
Wheel weight removal tip
Old 03-05-2017, 10:54 PM
Verboden
Verboden's Avatar
Default Wheel weight removal tip
I have had a problem with the adhesive type wheel weights falling off from the heat of tracking. Another rennlister suggested using duct tape (the tape used on actual ducts - metal backed) over the weights and that proved to work quite well. Problem is that tape can be a bitch to remove.
I am about to mount new tires and tried using a heat gun to soften the tape and it worked very well. Not only did the tape pull without ripping, it took off the weights as well. Some light scraping and much of the residual glue was off. Followed up with some acetone I had laying around. I had to use the high setting on the gun, not confident a hair dryer would cut it.
Before anyone comments about not running weights, other threads go into that.
Old 03-05-2017, 11:11 PM
996AE
996AE's Avatar
Received 1,449 Likes on 956 Posts
Goof Off or GooGone
GooGone is what I use with great success on my wheel wieght glue left behind.
Quick Reply: Wheel weight removal tip
