F/S wheels and tires, HRE 545 18x8.5 and 10 ...993 NB fitment
https://rennlist.com/forums/parts-ma...b-fitment.html
SOLD ... Thanks RL!
HRE 545 (r?), excellent condition, 993 narrow body fitment,
18x8.5 front with an old pair of 225/40/18 Yoko ES100's, camber wear on inside tread block,
18x10 rear with near new Hankook Ventus V12 (mid 2014 date code) 265/35/18.
Pics speak for themselves,
Plese PM your email for high res pics
SOLD ... Thanks RL!
Last edited by Russ in VA; 04-18-2016 at 02:51 PM. Reason: Added link to classified add in parts marketplace
To answer a frequent question, all four wheels have the same number stamped in back (see pic). Apparently HRE does not label with the offset. I did some careful measurements though and found that, as expected, the 8.5" wide fronts measure 9.5" at the edge of the barrels and the 10" rears measure 11". The backspacing to the edge of the barrels on the front is 6 1/2" and the rear is 7 9/16". My math puts the offesets at 44.5 mm in the front and 52.4 mm in the rear. To check my methodology I did the same exercise on my MY02 wheels and got withing 1mm of the ET stamped in the wheel. The PO said he called HRE with the number that's stamped in them and they confirmed that that they are 993 NB fitment. As I understand it he did not ask and was not told the offset ... not sure if HRE will share that or not? Thanks!
