991 20" Sport Classic replacements
4th Gear
Hi
I currently have the 20" Sport Classic wheels on my 991 C2 50th Anniversary:
F 9x20 245/35 ET51
R 11.5x20 305/30 ET48
http://www.suncoastparts.com/product/SKU50YRWHL.html?Category_Code=991SCHASSISWHEELS
Since I will be tracking the car I wanted to step down to 19's with optimal rubber sizing.
1
Does anybody have anything to say about Avant Garde Ruger Classics?
http://www.avantgardewheels.com/ruger-classic.php
2
... with Toyo R888's
F 8.5x19 235/35
R 11x19 295/30
The wheels seem to be reasonably priced at $1,700 and as you can tell, I like the classic Fuchs look.
3
Otherwise I have my eyes on a used set of OEM 997 Turbo 19" wheels on eBay with close offsets (F 56 / R 51), so 7-10mm spacers would make sure they work while widening track a bit.
4
For either wheels I'm looking at Toyo Proxes R888's rather than the typical PSS or PS0 setup.
http://www.tirerack.com/tires/tires.jsp?tireMake=Toyo&tireModel=Proxes+R888
So I'd like to hear feedback on rubber and track sizing for new 19's, keeping in mind that they are disposable
Appreciate any input or recommendations for a good set of track wheels/tires that won't break the bank (HRE's).
They're more for go than show.
Thanks in advance!
F 9x20 245/35 ET51
1
2
F 8.5x19 235/35
R 11x19 295/30
3
4
Thanks in advance!
For the track I would recommend forged wheels. Especially for such a heavy car.
CCW is a good option that is usually reasonably priced.
http://ccwheel.com/
Keep in mind with any different wheels, it's quite likely you'll need another set of wheel bolts. You definitely will if you use spacers.
If you go with used wheels for the track, I would make sure they've been used very little with a known history. And if they've been messed with (repainted or reassembled if multipiece), that it was done properly.
Fuchs, the original manufacturer of, well, the original Fuchs, now remakes them in 19", and they probably offer a 991 fitment. Probably quite expensive though.
Or these come in 18". Not sure if that clears your brakes though. http://www.52outlaw.com/wheel/
These come in 19", but are quite pricey. http://rotiform.com/products_fuc.html
BTW, your tire selection of 235/35-F and 295/30-R is quite a bit smaller in diameter than your stock setup. <---Edit: ignore that. Did not take into account wheel diameter change!
http://ccwheel.com/
