Center lock wheel alignment tool source?
Are there alternatives to the 3R Racing alignment tool? An essential piece for dis-mounting and mounting center lock wheels, but the only one I have found is the anodized 3R tool. It is a beautiful piece, but at $380 it is very expensive. It would seem that Porsche would include at least a plastic piece to align wheels fro mounting. Have not gotten my TTS yet, just want to be prepared. Hopefully a two/three piece 48" torque wrench will suffice without having to get a single piece 48" breaker bar too. Suggestions welcome. Thanks. Just need to have the right tools in the event that I am nowhere near a dealer and need to plug a tire to get me home if there is a flat.
No. I bought the 3R Racing wheel alignment tool. I have been told that it is not necessary by another TTS owner, as there are guides on the hub, but I have not taken a wheel off yet to experiment. Seems to me a lot easier and safer to use the mount/dismount tool to reduce the risk of damaging the ceramic composite rotors. There are less than 2 inches of clearance between the rotor and the wheel barrel on the fronts. If I had iron rotors I would not have gotten the 3R piece. I also got the Precision Instruments 200-600 ft. lb torque wrench.
Thx. I bought a used OEM breaker bar and the PI torque wrench. I know the aluminum guides for the standard wheel were useful. I'll hold off on the centering tool unless I find I have a problem if/when I try to take off a wheel.
