How do you paint race wheels?
I have a frustrating puzzle that I hope you can shed light upon..I have several sets of track wheels that I have painted like I paint other body parts. I first sand them, then prime them with primer, then I paint them with a car paint color and then followed up with a clear coat. They look great, but as soon as I take them to the track the red hub centers and half way down the arms of the wheels turn black which I can't remove. It seems to be heat generated. Has anyone had this happen before or know how the race teams paint their wheels so this doesn't happen?
Here are some pictures. It looks like dirt or brake dust, but I can't remove it.
I keep thinking my brakes are burning the paint, but I haven't heard of others having this issue with the Spec Boxsters and I can't find any discussions of people using special paint on race wheels. I have a second set which are red and have the same color change, but on my 997, I had powder coated blue which stayed factory fresh after years of track days
Richard
Richard
I have seen that on center lock Speedline race wheels. I have always assumed it was the high heat causing the literal burn of the painted surface. jdorociak@gmail.com jim
thanks for the response.
It almost seems like I need to use to engine or high temp paint, but I don't see anyone suggesting that in the forums and I am sure the cup cars generate more heat than my 986. The only thing I can think would be different is maybe the primers are less stable or heat resistant.
I wrote an article last year about race wheels. The best suggestion was to use rattle can paint. Don't laugh - it works right at the track between sessions.
I think you've most likely got brake pad material melting into the wheel. I've had it melt right into my aluminum wheels. It is around 1100 degrees when it leave the pad.
Here's the article.
Richard Newton
Race Car Images
Here's the article.
Richard Newton
Race Car Images
Former Vendor
