Shaking wheel. Need help
Just got back from Dexter day at Mosport. 20 minutes into my 1st session my right front started to shake thru corner 2 & 4 then all the way up the str8. On Fiorano's suggestion I adjusted the tire pressures & went back out. Same problem. Took a pro driver out, same problem.
Fiorano checked the ball bearings & front end. No problem there so they thought it was my new PZero C. After rebalancing the wheel still same problem. I left the track & went to Tireworks to explain the problem. They suggested to flip the wheels. Ran the car hot & now the other side shook. They put on another new tire & it still shakes. Now I'll try buying a new wheel. NE1 have any other suggestions or experienced these ailments. They suggested to flip the wheels. Ran the car on 410 & now the other side shook. They put on another new tire & it still shakes. Now I'll try buying a new wheel. NE1 have any other suggestions. |
Did you check the torque on the hub? Other than that I don't have a suggestion.
Greg |
If it does it when applying the brakes, it is a warped disk.
Spider911 88 Carrera |
Although it already sounds like the wheel. Do you know anyone who would allow you to try their wheel, just to be certain.
