Wheel and Tire Forum
Tire sizes for 15" wheels- strange....
Old 09-09-2002, 08:03 PM
GentlmnGQ1
GentlmnGQ1's Avatar
Question Tire sizes for 15" wheels- strange....
I have 15X7 wheels on the front and 15X8 on the rear of my car. The tires are 215/60R15 all the way around and have always thought this looked kind of funny. Anyone else notice this? After looking online, I found that this is indeed the size tire put on these wheels from the factory.
Why would porsche put the same width tire on wheels that were 1 inch different in width?
What size tire can I put on the rears to increase the width without affecting the height(speedo issues, etc.)?
Old 09-09-2002, 09:23 PM
Randy
Randy's Avatar
Post
A buddy of mine with a 74 Carrera and 15 x 7/8 uses 245/50-15 Dunlop SP8000 tires on his 8's, and 225/50-15's on the 7's. He has to run 2+ degrees negative camber to avoid rub, but they look great. You can find them at the tire rack. FWIW, a lot of folks running 15 x 7/8 Fuchs use 225/50-15 tires all the way around, with no balance problems.
Old 09-10-2002, 01:40 AM
GentlmnGQ1
GentlmnGQ1's Avatar
Post
So, with 225/50-15's I won't have any problems with the speedometer reading incorrectly?
Old 09-10-2002, 09:03 AM
stefang
stefang's Avatar
Post
You will get a speedo error. Check out this <a href="http://www.miata.net/garage/tirecalc.html" target="_blank">tire size calculator</a>. A 245 is probably the max you can cram on an 8" wheel. 225 is fine. Check at <a href="http://www.tirerack.com/index.jsp" target="_blank">Tirerack</a> on specific tires. In the spec section they will list min/max wheel sizes for each tire.
Stef
Quick Reply: Tire sizes for 15" wheels- strange....
