Disassembly, BBS/Sport Design Wheel
I want to remove the center portion of the wheel and would like to know if anyone has disassembled this type of wheel? If so, any problems with the reassembly? What were the torque settings for the bolts and was there a sequence in replacing and tightening the bolts?
Thanks for your help.
It is super easy....take a ratchet and break them all lose, use a electric impact gun if possible saves a ton of time to remove. The bolts are titanium so don't screw them up and lose them, they are expensive. When you reinstall them 16ft/lbs each and you are all set.
Very easy to do
Very easy to do
