Porsche Techno Twist damage(?)
Was at the Porsche dealers getting some warranty work done. The service manager mentions that they have a guy that drops by two days a week and resurfaces curb rash off of wheels, says he could work on my rear driver wheel, since the car was there anyway. Fine by me. After thinking about it, I call back and mention that I would really like the guy to work on my summer wheels (which are off of the car) so I drop them off the next day.
Here' the story from the dealer: he said the wheel refinisher said there was a "crack" in the wheel and that he wouldn't touch it. The "crack" is a buckling of the paint about 2-3 mm more central to where the wheel edge hit the curb. Pretty subtle unless you are looking for it.
I had thought the "crack" was going to be a defect in the metal alloy that I could see. The dealer essentially was trying to quote me prices for a new wheel.
Would you:
1- replace the wheel
2- drive it as is
3- refinish it yourself (I have the filler, and EinZed paint/primer/clear coat)
BTW the incident with the curb was > 1 year ago and I drove that wheel until this last winter, w/o any difference I could tell.
Would you:
2- drive it as is
At the very least I would recommend getting a second opinion from a wheel refinisher that doesn't have any interest in selling you a new set of wheels. If there is a crack or other safety issue, replace it.
There are lots of wheel refinishers around my town, hopefully you have a similar situation.
You'll want someone who can repair a minor crack. Most mobile guys just paint.
The serious repairs are blast clean, straighten/weld/true, then refinish.
Any crack near a structural element (ie a spoke, etc) will be harder to repair or impossible.
I would NOT drive with a crack nor would I fill it myself.
GL
A
GL
A
GL
A
GL
A
Adam,
Thanks for the tip. Sought out the opinion of a wheel guy and here is the scoop:
1- Mobile guys are just interested in doing what they can accomidate quickly, their opinion on issues that require more expertise than they perform is suspect.
2- Cracked paint is just that, cracked paint. The aluminum alloy is just fine (in my case).
3- Because of the above, the wheel is safe to drive as is.
4- IF there had been a crack in the metal: if the crack runs in the direction from the center of the wheel outward (like a spoke) the wheel is fixable. If it runs paralleling the rim, like an arc, the wheel is unfixable and unsafe.
I'll get it back in a few days.
BTW: get them to clearcoat the inside of the rim to ease your cleaning/upkeep on the wheel.
