Question for wheel and tire experts - 996 C4S
I have a 2003 C4S that I bought snow wheels and tires for last year. Because the winter wheels are narrower, I also have to put 17 mm spacers on with the winter wheels. My C4S came with Sport Techno wheels and spacers that are about half as thick as the 17s. Would there be any advantage or disadvantage in leaving the 17 mm spacers on the car instead of re-installing the thinner spacers the next time I put the summer wheels back on?
the wider stance you would get from the bigger spacers can give you better handling - it can also add high speed instability and wander - that part all really depends on your alignment settings - also, check interference issues carefully - i don't know that car or the fitment of those wheels, but you may have issues with outer interference at the extremes (like fully loaded and in a big off camber bump, etc)
Wheel Enhancement can probably give you really good input on the specifics of your setup
Keeper of the Truth
