Rolling inner fenderlips
Mr. Excitement
I did not own ether one that I have made to fit 130 mm 5 bolt patterns. Both are in the Wash DC area. I will contact the owners and see if ether want to set up a rental service.
What I did was to cut the outer ends of the existing oval shaped holes and weld on prebent 3/8 bar stock to reinforce the bolt ring. If the added metal is not added the ring is easy to bend and unless care is taken will deform when used.
Originally Posted by MarkT.Bevans
Looking for info on rolling my innerlips so I can use 17" wheels on my Carrera. Do mos people cut them, then carefully pound them under? Or?
Mark
Mark
I've seen roller tools in tool rental outlets for about 30.00 a day you might want to check that out.
