Hubcentric rings for different center bores
Hey Folks,
Question regarding wheels compatibility for a BMW application ....X5 (5.0) to X5M
BMW X5 (5.0): Has the wheels i'm interested in (Rear) 74.1 center bore
BMW X5M: (Rear) Center bore is 72.5
There are hubcentric adapters as well as hubcentric rings to do the conversion from 74.1 > 72.6 (.1 mm bigger...72.5 vs 72.6)... Would that be significant enough to feel the effect in street driving? Are these adapters regardless of being hubcentric, pose vibration issues?
Personally int he past, I have always bought appropriate offset wheels to avoid the spacers/adapters but these wheels seems too good to pass, hence my inquiry into the adapters?
I had some H&R Hub centric adapters on my old M3 and had no problems. I even abused and tracked that car without any problems. Given their history with BMW product, they may have an application for you.
0.1 mm is not something you are going to feel or notice. Honestly, with the clamp load being through the lug interface you aren't likely to notice a lack of hub centric rings if you skipped them altogether. Matching the bore just makes it easier to get the center of the holes in the wheel aligned with the center of the stud or bolt holes in the hub. Once you torque the lug nut / bolt there isn't much loading going through the center. Everything is from the bolts outward.
