Unknown wheels
Are there any markings? That spoke style is the famous "Minilite" style, but many companies made similar wheels. Even within the Minilite brand, there are many different variations of hub and spoke treatment.
There appear to be steel inserts at the lug holes, which suggests they are magnesium.
I would post on PelicanParts or EarlySRegistry - someone there has surely seen these.
They look similar to these, which are supposedly real Mg Minilites: http://forums.pelicanparts.com/porsc...eels-sale.html
As is suggested in that thread, I personally would have them tested for cracks if you want to drive on them. Even then, you need to regularly check for corrosion. Magnesium isn't the strongest material, and 50-year old technology wasn't great.
Thanks French Toast.
I couldn't find any markings on the rims. I'll definitely post on suggested sites and see what comes back.
Just wanted to know if those wheels are worth anything as I'll probably get Fuchs back on the car after restoration.
https://www.design911.co.uk/fu/pt72_...heels-15-inch/
A refinish would probably be close to $100 per wheel
Cool wheel though
You can purchase them (15") new for about $160 or so
I would bet the wheels you have are genuine period Minilite Magnesium wheels. They are fairly coveted, despite the fact you'd be insane to drive on them. They were often used on the rear of early racing 911s before wider Fuchs were available.
If it's a magnesium wheel, to have them properly refinished would cost a good amount more. When refinishing, you'd be dumb to not at the least have them magnfaluxed once they are stripped. X-raying is ideal. Perhaps it isn't necessary if the car is only going to roll on them at walking speed.
I personally wouldn't trust a 60's magnesium wheel to go any faster than a Zamboni machine.
They might be okay to putter around on if you have them inspected. Plenty of people surely drive on them - old Ferraris and Lambos often have similar era magnesium wheels. The technology was rudimentary then. The technology is better now, but Mg wheels still have a much shorter lifespan than aluminum-alloy counterparts.
Just look up "magnesium wheel failure."
Between the fatigue and possibility of cracks and corrosion, I would put them on the wall.
But, due to fatigue I also wouldn't run original Fuchs on a track car either.
Don't get me wrong, I am not saying they are trash. But to me they are more of an art piece. With the amount of load and heat cycles wheels undergo (increases with tire technology), I simply would prefer to drive on something a little more sound.
They are rare, and a somewhat significant part of Porsche wheel history, as many period racers used them.
I'm not familiar with early days racing and I clearly missed that part on wheels. Good to know that it's collectible item and I will for sure follow your recommendation with modern wheels.
I was just wondering what I had there and it's great to have knowledgeable people around to educate me. So much history with Porsche
