Pirelli PZero Tire Leak
I have a slow leak in my left rear Pirelli PZero tire on my 2013 911 C4S Coupe. It's leaking about 7 pounds of air every 72 hours, which seems to be a relatively slow leak. Are these tires able to be patched depending on where the leak is? I know they're prone to leaks...
Cheers,
Nate
Cheers,
Nate
I have PZero's on my F-Type, and the warranty booklet says that if the leak is in the middle of the tire, it can be patched. But if it is on the wall, it will need replacing. Hope that helps!
